Easy fix?
Old Nov 24, 2008 | 07:45 PM
turbo11g's Avatar
Easy fix?
Is this an easy fix?
Old Nov 24, 2008 | 07:54 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
Re: Easy fix?
Old Nov 24, 2008 | 08:06 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Re: Easy fix?
Originally Posted by Brennan
HAHA! You beat me to that one Brennan!!
Old Nov 24, 2008 | 08:20 PM
Brennan's Avatar
Re: Easy fix?
threads like this are showing up alot lately like this one a little while ago https://www.thirdgen.org/forums/body...-electric.html
Old Nov 24, 2008 | 08:31 PM
Re: Easy fix?
HAHA! I have seen lots of this!
So turbo,care to clarify what the problem is?
Old Nov 25, 2008 | 06:17 AM
turbo11g's Avatar
Re: Easy fix?
The problem is, pictures aren't showing up.
Old Nov 25, 2008 | 06:22 AM
turbo11g's Avatar
Re: Easy fix?
I can buy this car for $650, needs carb. I'm not much of a body man, but I'm one hell of a welder. That's the only rust spot on the car.
Old Nov 25, 2008 | 01:24 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: Easy fix?
A Carb'd IROC-Z?
Old Nov 25, 2008 | 02:43 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
Re: Easy fix?
Originally Posted by bradley23150
A Carb'd IROC-Z?
LOL!!!
i guess it must be an aftermarket "hotrod" carb.
FI > Carb
Old Nov 25, 2008 | 02:54 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: Easy fix?
A Carb'd IROC-Z?
Originally Posted by RED_DRAGON_85
LOL!!!
FI > Carb
You could get a carbed IROC (L69 engine) in 85, and I think still in 86-87 as well.
That looks like some serious rust there, the short answer is no, it's not an easy fix. If you have the tools to cut out the rust and weld in a new panel, it's not impossible, but definitely will take some work.
Old Nov 25, 2008 | 03:16 PM
Brennan's Avatar
Re: Easy fix?
now thats something that makes more sense lol. its definitely not what i would call "easy" but its fixable without a doubt, assuming its dont spread much further then that.and there are plenty of factory carburated irocs out there
Old Nov 25, 2008 | 03:41 PM
SolarGoldRaptor's Avatar
Car: 1984 Pontiac Firebird Trans Am
Engine: V8 5.0L HO (L69)
Transmission: B&W T5
Axle/Gears: 3.73 limited slip
Re: Easy fix?
I think it would be easier to change the whole fender, look at the hole behind the ground effect !
I'm sure you can find the easily in the US.
Old Nov 25, 2008 | 04:09 PM
turbo11g's Avatar
Re: Easy fix?
Looks like some of these so called experts don't know their irocs? Yes, carbed, 305 HO L69 engine.
For $650 would it be worth fixing? I've done small rustorations, but it looks like I'll have to cut quite a bit out. Can I just buy the panel from the body line down? \
Old Nov 25, 2008 | 04:51 PM
Brennan's Avatar
Re: Easy fix?
if your takin about the crease at about the half way mark yes i bought one about 2 months ago cuz mine was rusted under the gfx in that spot IIRC it was 30-40 bucks
Old Nov 25, 2008 | 05:04 PM
turbo11g's Avatar
Re: Easy fix?
Brennan, where did you get it?
Old Nov 25, 2008 | 05:18 PM
Brennan's Avatar
Re: Easy fix?
i bought it from napa but they ordered it from here http://www.crosscanadaparts.com/cgi-...ml?img_num=699 part # 699-60R
Old Nov 25, 2008 | 05:55 PM
irockid86's Avatar
Car: 88 iroc camaro
Engine: jasper 350, l98
Transmission: 700R4, corvette servo, shift kit.
Axle/Gears: stock
Re: Easy fix?
if the rest of the body is solid, the engine runs strong, and the car has not been "modified" too much, I say buy it.
Old Nov 25, 2008 | 08:25 PM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Re: Easy fix?
How come nobody around me has projects like this I could work on. Easy fix? ... yes! If you know what you're doing.
Old Nov 26, 2008 | 12:25 AM
turbo11g's Avatar
Re: Easy fix?
What makes this NOT an Iroc? That the pretty wheels are gone? lol
Old Nov 26, 2008 | 03:23 PM
Brennan's Avatar
Re: Easy fix?
i know why its not an iroc, no iroc wheels and its carbed also the stripe delete [/sarcasem]
Old Nov 26, 2008 | 04:16 PM
turbo11g's Avatar
Re: Easy fix?
Old Nov 26, 2008 | 07:30 PM
irockid86's Avatar
Car: 88 iroc camaro
Axle/Gears: stock
Re: Easy fix?
iroc was really just a package anyways. who cares if it is an iroc or not? if the car is in good condition 650= good deal.
Old Dec 20, 2008 | 07:52 AM
turbo11g's Avatar
Re: Easy fix?
The guy is getting desperate. I held off for awhile, now he's down to $500!! SOLD, to me! Going to get it today.
Old Dec 20, 2008 | 09:07 AM
Brennan's Avatar
Re: Easy fix?
man what a deal! whats the mileage on it?
Old Dec 20, 2008 | 01:31 PM
turbo11g's Avatar
Re: Easy fix?
odometer says 77000. I ran the vin on carfax due to the salvaged title. It reported an accident with no structural or frame damage, and the odometer reading was inaccurate. The engine code says it was a 305 TPI, which is gone. I did find 305 tpi motor and trans for $500 with the computer and all the wiring harness. 72000 miles out of a 92 bird. It needs door hinge bushings, inside door handle, radio bezel. Just needs some tlc and a little rust repair and some paint. I'm thinking black with hugger orange hockey sticks. Kind of like this one.
Old Dec 20, 2008 | 08:58 PM
Re: Easy fix?
I never claimed to be an expert.
Old Dec 21, 2008 | 02:26 AM
Brennan's Avatar
Re: Easy fix?
im pretty sure that car is owned by someone on the boards. no idea who youve got your self a nice project there. it sucks that someone would ditch the tpi motor tho
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
gta892000
Aug 11, 2019 11:16 AM
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
92firebirdguy
Sep 1, 2016 07:53 AM
85 Jimmy
Sep 30, 2015 07:56 AM
