body work and paint
Old Jan 6, 2009 | 08:02 PM
Hartmann's Avatar
body work and paint
Hey I need to fix the rocker panels of my IROC they are gashed. I also need to fix the drivers door has a dent sort of towards the bottom and goes onto rocker panel how would I fix that? What is the best way to fix the aforementioned things, details if possible like what to buy and how to do it. Also if I were to sand and repaint the car where would I be able to purchase the IROC door effects, or are they removable?
Thanks Everyone
Erik
Old Jan 6, 2009 | 08:27 PM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Re: body work and paint
What you're asking us to do is almost impossible. If you can post some pics of the damage maybe we can give you some helpful advice. And remember ... while everyone here has the best intentions, not everyone gives the best advice. Following some peoples suggestions can really mess things up.
Old Jan 6, 2009 | 08:29 PM
Hartmann's Avatar
Right my mistake will upload pics and post.
Old Jan 6, 2009 | 08:56 PM
Hartmann's Avatar
pics.
Hood was from a wax job I tried, was stunned when it happened. The paint was fading but not nearly that bad.
Old Jan 7, 2009 | 07:14 PM
Hartmann's Avatar
Pics posted now.
Old Jan 7, 2009 | 07:47 PM
Car: 86 T/A
Engine: 5.0 TPI
Looks like your car has a few issues. The ground effects can be repaired with a plastic repair material available at your local autobody supply store. We use products at the shop from this company http://www.urethanesupply.com/ and they have some good how to info on their site. The bumper could also be repaired with this system. As far as giving you detailed info on how to do this, there are books written on the subject and they do a better, more thorough job of explaining it than I could here. I will say it isn't something you're just going to read a few directions and do. Learning the correct way takes time and practice to get even a moderately good job.
Old Jan 21, 2009 | 02:38 AM
jay_d's Avatar
Car: 84 z28
Engine: 355
Transmission: TH350
Axle/Gears: one wheel peel
or you can cut through the crap cake of buying that high *** plastic repair kit and use fiberglass on it, i think it holds better my self. What your gonna want to do if you choose my method is to take the part(s) off the car so you can get to it (i swear its worth the time) on the back side of where its cracked. take some 80 grit sand paper and rough the back side up real good, then cut your piece of fiber glass mat to the right size to mend the broken area, apply a thin coat of the fiber glass resin to the backside of the area being repaired, then press down your mat, repeat this process until you have 2-4 layers of fiber glass mat stuck on. After that LEAVE IT ALONE for 5 or 6 hours.
Next step is to turn it over and work on the side you are going to see, i usually grind it a little more smooth with a angle grinder then put a little body filler over the area.
now that you have a seemless area that is sanded smooth with no pinholes or wavy spots, get some 2k high build primer and put enough on it that you cant tell that filler is there, and you cant see any sand scratches (if you finish sand with 180 grit you wont have to worry)
next (if you are sure its 100% straight or just dont care, skip this step)
take a can of flat black spray paint and mist it over the entire area you have primered. dont paint it black, just enough paint to know its there. After you have your guide coat ready get a sanding block with 180 grit on it, sand off all your guide coat, if any black spots are left then that is what you call a low spot, it will need to be filled, or you will have what looks like a dent. after you get it to the point that you are satisfied prime it one more time and wet sand it with 400 then with 600 and its ready for paint
Old Jan 21, 2009 | 09:06 PM
Car: 86 T/A
Engine: 5.0 TPI
jay-d has recommended using rigid fiberglass and body filler to repair a flexible plastic part. While each of your cars ground effects pieces and bumper are not made of the exact same material a polyester resin and glass cloth repair on your urethane bumper would not be a good idea.
Old Jan 21, 2009 | 09:16 PM
360Iroc's Avatar
This is true. I can back up using urethansupply.com, I have order 1000's of dollars of material off them. Another company to look for is Dominion Sure Seal. They make a great 2 part flexible filler. I would use it over anything. From getting to use just about everything available to the market, their products top them all.
Old Jan 22, 2009 | 04:54 PM
jay_d's Avatar
Car: 84 z28
Engine: 355
Transmission: TH350
i dont think hartmann wants to spend a boat load of money on stuff to fix a bumper, in reality it is more cost effective to buy a new part than repair the old on using you guys method. Ive fixed alot of bumpers with fiber, and some i see everyday and they give no trouble, and never will. You guys are like the folks that try to push flex agent on bumpers. If you wanted to get technical on this, the best way to fix it is to invest in a plastic welder, ive used the ureathane bumper repair kits before, and they are **** if you want somthing to last, but if you want to spend the money on the crap, take the time to paint it back, and then have a nice crack where it fell out from the back sides, then by all means do so
Old Jan 22, 2009 | 07:51 PM
Car: 86 T/A
Engine: 5.0 TPI
If you check the link I posted you'll see they sell the plastic welder I use. And they have a lot of good how to info on how to use it. In my opinion the first time the bumper you fix even gets close to a curb or bumped in a parking lot, or even driven fast and subject to the stresses of the wind, your repair will fall apart. It can't help but break loose it's not flexible. We all have our opinions and I'm not going to change yours. And you are correct doing it the first time with materials designed for the job may cost a little more. But probably not as much as doing it twice.
Old Jan 22, 2009 | 08:37 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
jay_d is correct,fiberglass works quite nice and less expensive. 1piece,I have never seen a repair on a tpu bumper fall apart from driving or getting close to a curb(care to elaborate?)
These parts aren't really that flexible that I know of.
Old Jan 22, 2009 | 08:45 PM
Car: 86 T/A
Engine: 5.0 TPI
We're talking about 3rd gen bumpers not TPO
Old Jan 22, 2009 | 09:00 PM
well yeah,this is a third gen site!What did you think I was talking about?
Is TPU not the correct material for a thirdgen bumper?
What is TPO? Perhaps some fiberglass would fix a tpu bumper and not a tpo bumper?
That still doesn't answer my question or perhaps the original posters question.
How can a fiberglass repair simply fall apart when driving or getting close to a curb?
Old Jan 23, 2009 | 05:23 PM
jay_d's Avatar
Car: 84 z28
Engine: 355
Transmission: TH350
look all i know is that if you dont wanna spend $250 bucks on a plastic welder (i have one btw) then fiber glass is your best bet, ive used it alot before i bought my plastic welder, and further more Im an ASE certified auto-collision repair technician and if you wanna do it the right way my friend, the book says go buy a new bumper
Old Jan 23, 2009 | 06:48 PM
zoocrewsr's Avatar
Car: 89 RS
Engine: 2.8
Transmission: 5 speed manual
Axle/Gears: 7.75" 3.70 gear 9 bolt
How would you recomend repairing a hole in the front bumper at the bottom where it looks like it rubbed against something??
Also where would i find a trim piece i need i have checked junkyards, and i cant even get it at the auto parts store i work at, it is the right rear quarter panel trim piece???
I will try and post pics...
Old Jan 23, 2009 | 06:59 PM
zoocrewsr's Avatar
Car: 89 RS
Engine: 2.8
pic 1 of 3...
Old Jan 23, 2009 | 07:00 PM
zoocrewsr's Avatar
Car: 89 RS
Engine: 2.8
pic 2 of 3...
Old Jan 23, 2009 | 07:03 PM
zoocrewsr's Avatar
Car: 89 RS
Engine: 2.8
pic 3 of 3...
Old Jan 23, 2009 | 07:08 PM
jay_d's Avatar
Car: 84 z28
Engine: 355
Transmission: TH350
sand it down, put a lil fiber glass mat behind it, and put filler in that hole.
The trim piece is the passenger side ground effect, just tell em the one behind the back wheel, hawks sells em i think, if not you may have to scrounge around some junk yards, as most people hang on to the ground effect kits, because everybody wants em
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Exxon Limited
Aug 9, 2015 08:13 PM
