Would C5 Z06 Rims fit a 92 without adapters?
Car: 1992 Chevrolet Camaro-Z28 25thAnniv
Engine: L98 5.7L TPI
Proud owner of a 92' Z28 Camaro.
Somehow, the rims that came with the Heritage Package have faded and I've never seen or heard of this happening before. Rather than having them painted, I've decided to just get new rims.The rims I've fallen in love with are C5 Corvette Z06 rims. If you look at the picture below I had come across, its an Fbody with those exact wheels. When I go looking for the rims, they say they only fit 93' camaros and up. What kind of adapter for the bolt pattern would I need to make them fit? And if so, does anyone know where I could find such a thing?
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
Re: Would C5 Z06 Rims fit a 92 without adapters?
www.skulte.com will have what you need. Most people use the 2" adapters for vette and 4th gen wheels. The bolt pattern is the same for your can and the wheels.
Unless it's a custom wheel, I can almost guarantee you're gonna need wheel adapters as other posters have said.
It has to do with the wheel offset, and you can tell pretty much by looking at them. If you look at the corvette wheel the spokes are even with the outside of the tire rim. If you look at a stock camaro rim, it has an offset... which means the center hub of the rim is actually inside the rim of the wheel, unlike the corvette rim where the hub, spokes, etc. are all even with the outside of the rim of the wheel.
So like I said, you can get a custom machined wheel, or run adapters. Adapters = one more thing to worry about coming loose for any reason. Plus you have to worry about whose making a quality adapter and what is junk. And it's extra cost on top of it. On the flip side you'll be able to run a lot of front wheel drive type rims with the adapters that you couldn't before. Pop open a summit racing catalog sometime.
Mathius
Mathius
Car: 91 z28
I have the same wheels on my 91 z28 "I love it " ,2" inches is what you'll need ,I never had a problem with the adapters ,and a I like the way they look .
Car: 87 GTA
Or...Just get adapters for the front & put in a 4th gen rear end.
No need for adapters for the rear then, plus you get the bigger brakes & stronger differential.
All in all...A better rear end.
Car: 1991 Formula Firebird
Engine: Pontiac 355 stroker (305 TBI 4Sale)
Transmission: Pending Manual , 700r4 for sale...
Axle/Gears: Stock... for now
Car: '92 Z28 Convertible
Engine: 305ci TPI
Transmission: 700R4 shifted
Axle/Gears: 2.73 (for now)
Sounds like a good plan!What kind of condition are your originals in other than the fading? I've been looking for an original set for my '92 - do you think you'd be interested in making a few bucks and selling them?
Other than a bit faded, they are in great shape, for being 17 years old of course. But as for selling them; as of now, probably not. But I could get back to you after I get everything straightened out with these rims and let you know if I changed my mind.
Car: 92 camaro
Engine: stroker
Transmission: Megaraptor
So, thanks to all the help I got, i ended up buying 4 17" C5 Rims.
The tires are Firehawk WideOvals
I'm just waiting on the spacers to come in and then they'll be going on.
Thanks again for the help
Car: 91 Firebird, 06 Dodge Ram 1500 SLT
Engine: 3.1L, 4.7L
Transmission: 700r4, 45RFE
Axle/Gears: 3.23 open, 3.55?
The spindles isnt the problem. Its the offset spacing. Which is why you need to get 2in spacers. Like stephen said if you are running a 4th gen rear end then you dont need spacers. This is due to the difference in offset. Ive been looking into gettin these exact rims for my car. Id jump right on it but for right now id like to put the money into some other things first. That camaro in that pic looks really nice. I love the color, stance, everything. Who ever's car that is did a very nice job. A+ work.
Car: 1 68 bird, 2 87 birds, a 92 bird...
Engine: carb'ed 305 in the 87, yuck...
Transmission: 700R4, for now....
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
Transmission: stage2 700r4
Axle/Gears: 2.73 for now
Are thos 18's or 17's?...andwhat size tires?....anybody know?
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
I'd like to see some pics of them on your black car CTitalian3... I often wondered how they'd look on my black IROC.
I have the C5 Z06 rims on my '91 Z28 and I think it looks great, I too used Skulte 2" adapters front and rear.
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
hey brisk what size are yours??....and what size tires?
18" C5 Z06 Wheels made by AFS. These rims are 18x9.5 with a +56mm offset and 7.4" backspace, wrapped in Kumho Ecsta Supra 275/35ZR18's on all four corners.
Street Lethal
Apr 30, 2019 12:14 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
