Clearcoat
Old Mar 5, 2009 | 09:46 PM
383GTABoy's Avatar
Car: 88 GTA + Dakota on N20
Engine: 383 4 bolt
Clearcoat
My cleat coat is worn through on my 4th gen spoiler. Now it looks all dull and im wondering what would be the best way to fix her up.
My plan is to rough the entire spoiler up with 1000 grit then spray clear.
I have a Mini HVLP gun (used for painting Bikes) but i dont want to spend 100+ on a gallon of clear+hardener+reducer. Does anybody know if they sell smaller quantities of clear and if so where I could purchase it. Its either that or I use rattle can clear which I have never used before and am kind of afraid to try. One more question, about how much should I need to do it?
Thanks in advance
Old Mar 5, 2009 | 09:51 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Re: Clearcoat
they sell clear in any size you need (pint through gallon) and you should rough it up with about 600 grit before re-clearing.
the clears not chipping is it??
you can buy it from any automotive paint supplier, the easiest place that I'd recommend is Napa, they sell dupont paints, which is a good brand.
Old Mar 5, 2009 | 10:23 PM
383GTABoy's Avatar
Engine: 383 4 bolt
Re: Clearcoat
No its not chipping at all it just looks like maybe the guy I had paint it 10 years ago went light on the clear. The 4th gen spoiler is perfectly horizontal and water just tends to sit there and weather it. Sadly my car had to spend the last 3 years outdoors until this last winter, Now it finally has its own year round home.
Ill give napa a try. How much clear and hardener do you think it will take for 2-3 coats?
Old Mar 5, 2009 | 10:52 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Re: Clearcoat
depending on the mixing ratio you might be able to get away with a pint of clear, since once you factor in the hardner/reducer or cataylist you really get around a quart of spray-able material.
Old Mar 5, 2009 | 11:12 PM
383GTABoy's Avatar
Engine: 383 4 bolt
Re: Clearcoat
Thanks for the advice, I just checked out your car domain. Wow that is one hell of a restoration. I did the same thing when I was your age (except I had the paint done) and now im almost 30 and still have the car. Never regretted the time or the money it took to do it either. One piece of advice, 300 hp will not be enough to keep you happy for long.
Old Mar 6, 2009 | 12:31 AM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Re: Clearcoat
If your clearcoat has broken down and worn off you may find that you need to start with a fresh coat of color before you reclear it. If there is still some good clear over the existing color you may be alright. And personally I think I'd go with 1000 grit or finer to preserve as much original paint as possible, unless the finish is in really bad shape.
Old Mar 6, 2009 | 06:57 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: Clearcoat
600 g
Old Mar 6, 2009 | 09:27 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Re: Clearcoat
thank you man, I hope I still have the Trans Am when Im your age, and yea I know that wont be enough, I have new plans (build the 700r4 up and possibly a 400+ hp motor, but nothing is set in stone.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Catcher55
Aug 15, 2015 07:08 PM
Troy 85Z
Mar 16, 2001 08:51 AM
Mike-88CamaroTBI
Jan 27, 2001 04:30 AM
