Headlight motor: check it out
Old Mar 7, 2009 | 04:33 PM
Justin1989's Avatar
Car: 1989 GTA
Engine: 5.7L TPI 350
Transmission: Automatic
So I got my new motors today and when I installed them only one of them works. The driver side will not even show signs of power to the motor. I also plugged the passenger side motor into the driver's side. It wouldn't work. But the passenger's side wiring will power either motor. I think it might be a wiring problem. Any suggestions? Quickly please, I gotta fix this today. Movies tonight, females involved, help me out guys!
Old Mar 7, 2009 | 04:38 PM
popballz's Avatar
Car: 89 firebird
Re: Headlight motor: check it out
it could be a fuse, but i would think that would be the same fuse for both lights
just start following the wires back from the headlights, thats what i would do.
Old Mar 7, 2009 | 04:46 PM
Justin1989's Avatar
Car: 1989 GTA
Not a fuse, but I've heard there are fusable links that can go. What exactly would I be looking for? Also this had to have just started happening because previously it would be be stripped but the motor would still turn. So what could go suddenly that is exclusive to the driver's side power?
Old Mar 7, 2009 | 08:31 PM
skitztikwon's Avatar
relay birds are bad about it you could always run a switch and from the other side and make it wink when you want it to or just run a wire to the other side until you can get it sorted out
Old Mar 7, 2009 | 10:24 PM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Axle/Gears: 3.70 Posi disc 9 bolt
I think that there is a relay on each light. Look for it in the engine compartment, forward.
Jim Berry
Old Mar 8, 2009 | 09:37 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
there is a relay box that is right next to the wiper motors
Old Mar 8, 2009 | 04:54 PM
Justin1989's Avatar
Car: 1989 GTA
Alright I see the relay box, but if it's bad, where can I get another?
Old Mar 8, 2009 | 05:26 PM
strc09's Avatar
Car: 1988 Pontiac Firebird Trans AM GTA
Engine: Tune-port Injected 6.3L
Transmission: Borg-Warner T56 six-speed
Axle/Gears: Borg/Warner 9-bolt with 3.70:1
Any parts store sells them. I've had to replace all the relays under the hood ove rthe course of ownership of my GTA.
Old Mar 8, 2009 | 11:11 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
http://www.top-downsolutions.com/pro...roducts_id=119
Lon
Old Mar 9, 2009 | 12:55 AM
Justin1989's Avatar
Car: 1989 GTA
I actually ended up taking that ^ apart and rebonding the burnt wires together. Both headlights flip up like a charm.
Total cost: 1/2 hour.
lol
Thanks guys.
GTAman
Mar 15, 2019 11:40 AM
Fox118
Sep 1, 2015 04:07 PM
Skwisgaar
Mid-West Region
Sep 1, 2015 08:41 AM
rh76camaro
Exterior Parts for Sale
Aug 29, 2015 06:53 AM
Fronzizzle
Aug 17, 2015 02:52 PM
