Gap between GFX...is this normal?
Old Mar 11, 2009 | 08:13 PM
BlueByU's Avatar
Car: 1991 Z28
There is this small gap between the GFX where they meet the bumper. It looks like the cause of the gap is a little rubber bump on the inside of the bumper that makes contact with the GFX. This gap, which is on both sides of the car, doesn't seem like it should be there. So I'm wondering if these GFX/Bumper were installed correctly(I don't know if they've been replaced or not).
Here are some pics to illustrate what I'm talking about.
Old Mar 13, 2009 | 07:59 PM
BlueByU's Avatar
Car: 1991 Z28
Re: Gap between GFX...is this normal?
Can anyone who has a 91-92 z28 verify that they have that little bump thing pressing on the ground effects? It's really easy to check, I would appreciate it. I don't think mine are on quite right.
Old Mar 13, 2009 | 08:06 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
i just looked at mine, i dont have that bump, it may be a molding thing that was never cut off at the factory? i donno... but i dont have them and my gfx line up perfectly, so i think you can just razor blade it off
Old Mar 13, 2009 | 08:09 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
Mine is not a Z car but a 92 and it dose not have it. It may have but fell off ?
Old Mar 13, 2009 | 08:46 PM
BlueByU's Avatar
Car: 1991 Z28
Ok thanks guys appreciate it. I just didn't want to go hacking away if it was supposed to be there. I'm thinking the bumper was replaced and whoever replaced it didn't slice those off.
Old Mar 13, 2009 | 10:37 PM
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
thats very possible, if you want i can take a pic of mine before you start cutting. lmk
Old Mar 13, 2009 | 11:32 PM
BlueByU's Avatar
Car: 1991 Z28
Actually I just got finished taking that rear part of the ground effect right behind the tire off and snapped a much better picture of this little ****(I guess it's plastic). I think it might supposed to be there so I'm going to leave it. I can just cut out a little "C" section of the ground effect I removed to fit around the **** and it should fit better.
Old Mar 13, 2009 | 11:42 PM
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Hmm i definitely don't have those (just repainted the car myself so im sure), but if cutting a "c" out will work that seems like a good solution to me!
Old Mar 13, 2009 | 11:47 PM
BlueByU's Avatar
Car: 1991 Z28
Hmm, mine is probably a replacement bumper then?
Old Mar 13, 2009 | 11:51 PM
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
its possible who knows, looks good tho so its all good
Old Mar 14, 2009 | 12:15 AM
popballz's Avatar
Car: 89 firebird
i got those on my front gfx. its suppose to be there i am assuming and there is suppose to be a hole in the piece that touches it so it lines up good, at least thats how it is on mine, and it would make sense if it was made that way.
Fanatic1074
Oct 3, 2022 05:57 AM
Linson
Oct 1, 2015 09:50 PM
dusterbd
Sep 29, 2015 08:40 AM
BWilcox
Sep 20, 2015 12:19 PM
Stroopwafel
Sep 11, 2015 06:38 AM
