Manual to power window conversion
Old Apr 11, 2009 | 05:23 AM
rallysport383's Avatar
Car: 1989 camaro rs
Engine: 383 stroker
Transmission: t5
Axle/Gears: 4th gen/3.55
Hello everyone, quick question here. Are the window regulators used for
manual windows the same as the ones used for power windows?
Old Apr 11, 2009 | 12:36 PM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Re: Manual to power window conversion
No. While the regulators have some similar parts, converting one would be a real challenge.
Old Apr 30, 2009 | 01:45 AM
OS3Fleming's Avatar
Car: 1984 Camaro Z28
Engine: 357 SBC
It took me a day to do the swap. cave some nuts and bolts ready you will need to drill out pop rivits.
Old Apr 30, 2009 | 08:06 AM
cdoyle's Avatar
It's not too hard a job too do, I used this as a guide when I did mine
http://www.p71interceptor.com/thirdgen/powerwindows/
Old Apr 30, 2009 | 08:36 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Or you can buy the Spahl window kit.. .they work nice... Quite a bit less work... Just an option...
Old Apr 30, 2009 | 03:57 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
__________________
That is an excellent tech article.
The only thing I would add, is to consider substituting 1/4-20x1/2" bolts,
with nylock nuts, for the rivets.
(Rivets are not inherently stronger, but obviously faster on a factory
assembly line.)
Old Apr 30, 2009 | 06:12 PM
Thirdgen Ranch's Avatar
Former Sponsor
Car: Too many
We sell power window/lock conversion kits that have everything you need.
Old Aug 29, 2010 | 11:49 PM
89redfirebird's Avatar
i have a parts car with power windows could i just switch the doors and whatever wireing from the parts car
Old Aug 30, 2010 | 12:04 AM
Former Sponsor
Car: Too many
Yes, you can just swap the doors and then install the harness in your car if you want to.
Old Aug 30, 2010 | 12:30 AM
Car: 86 T/A
Engine: 5.0 TPI
You could also swap the regulators out and keep the doors you have.
Remember that the window switches are in the console. It's not just a couple wires in the doors you'd be transfering over.
Old Dec 21, 2012 | 06:22 PM
morries's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
do you have a pic of the spal window kit installed?
Old Dec 24, 2012 | 11:08 PM
kmcn47's Avatar
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
iirc most if not all cars have the wiring in place under the console already, i know mine does, and its an 84, just taped away and un used
Old Nov 1, 2013 | 09:18 PM
roddr1968's Avatar
Car: 1968 RS/SS, 1989 Iroc-Z 350 (sold)
Engine: L98 5.7L V8
Transmission: 700R4 auto
If the wires are already under the console and unused.... are the wires in the door as well to hook up to the power regulator?
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
