BODY WORK HELP PLEASE
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
I have a 91 RS i just bought and the guy had put a scoop on it but it looks ugly is there any way i can fix this. Also the spoiler has some cracks and the front bumper is a little moved here are some pics.
Any help please
Any help please
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
Re: BODY WORK HELP PLEASE
whoever tryed to do that.....completely failed. I would just get a new hood man.....what kind of scoop is it? SS? If so, just get the hood..you'll have alot fewer headaches
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
the hood can be fixed, and you need to:
- sand it down with 220
- use glazing putty to fix imperfection
- Sand with 220 (forgot to mention it)
- epoxy primer (1-2) coats
- high build primer 3 coats
- block sand it with 600
- base / clear
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Thank you I will try today and were can i find the glazing putty, and do i go in the order you wrote them down.
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
yes you do them in order. buy glazing putty and sand paper from Autobody supply such as, Sherwin Williams. They are usually listed in yellow pages under "Automobile Body Shop Equipment Supplies"
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Ok so i would first have to sand down all the bumps down then put the glazing putty until it looks perfect then sand it with the 600 right. Also in the last picture it is from my spoiler is there any way i could fix that
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
try to keep the thickness of glazing putty to minimal (Do not exceed 1/8"). sand it with 220, and then epoxy,high build, block sand 600, paint.
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Ok is there any difference of the epoxy primer and regular primer or it would be best to use epoxy. Also by epoxy high build what you mean about that
Engine: 5.7
Who knows what materials/products has been used on that hood. Sure...you can "try" to repair it....but if you really want that scoop on a hood..just start over. When we restore or fix cars that have been worked on previsouly....we take out all of the old material....and fix it right. Chances are....when you try to fix someones hack job....it'll end up bad in the end.......
Terrell351
Jun 13, 2021 01:13 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
