Bought outer window sweeps from 1A Auto
Old Mar 1, 2010 | 07:55 PM
Mr Froman's Avatar
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
How do they go in? It looks like I just pull the old ones out and pop the new ones in but I need to be sure before I go ahead and mess something up.
Old Mar 1, 2010 | 07:59 PM
Samdweezel05's Avatar
Re: Bought outer window sweeps from 1A Auto
should just be some metal clips on the sweep that grab the top of the door. Pop the old ones out and press the new ones on.
Old Mar 1, 2010 | 08:00 PM
Mr Froman's Avatar
Do I have to take off the door panel to get the clips off?
Old Mar 1, 2010 | 08:04 PM
If you are talking about the sweep on the outside of the window you should be able to pull it up and off with out taking anything else off. It might fight a bit but it will come off.
Old Mar 1, 2010 | 09:22 PM
my82roc's Avatar
Car: 89 Iroc Convertible
All the ones Ive seen are held on with small 7mm bolts.To get access its easiest to pull the door panel off,then remove the 2 window felts so you can pull the glass away from the door a little bit.I removed a very nice one from a junkyard car and it was a real pita
Old Mar 2, 2010 | 06:29 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
82roc is correct . i replaced mine after new paint with 1a auto sweeps . was happy . don't expect all holes to line up perfect . not a1's fault , factory assy. was done on assy. line by humans . i used many small phillips head screws instead of 7mm heads . take your time , good luck .
Old Mar 2, 2010 | 06:57 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
https://www.thirdgen.org/forums/body...-shortcut.html
JamesC
Old Mar 3, 2010 | 11:01 AM
1Aauto's Avatar
Former Sponsor
Hey Froman, did yah make out with the install ok on these ? If you take you time and follow the advice given it's pretty straight forward.
Old Mar 3, 2010 | 09:00 PM
Mr Froman's Avatar
I had to do a little bit of drilling for the last hole above the door handle and it worked out just fine. Doesn't look 100% in that area because it sits a little lower on the edge of the door because the of how the holes don't line up perfect but it looks much better than it did. Thanks.
Old Mar 15, 2010 | 05:06 PM
Mr Froman's Avatar
One problem, my window sweeps do not sit tight enough against the window to keep the water out. Do I just have to adjust something?
BADNBLK
Convertibles
65
Feb 10, 2016 03:36 PM
1992Z28!
Nov 19, 2015 07:33 AM
scottmoyer
Sep 7, 2015 07:06 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
