Am i in over my head? rust?!!!!!
Old Mar 17, 2010 | 01:11 PM
91camarosRS's Avatar
Car: 02wrx/88 rs
Engine: 2.0L turbo/nothing yet!
Transmission: 4eat/waiting on a t56
i baught this car and am about to well put things short.... modify the crap out of it. but wondering if the rust is too bad? should i abort?
maybe its not that bad? i have another car for sheetmetal if needed
<a href="http://s734.photobucket.com/albums/ww342/91CamarosRS/?action=view&current=DSC00122.jpg" target="_blank"><img src="http://i734.photobucket.com/albums/ww342/91CamarosRS/DSC00122.jpg" border="0" alt="Photobucket"></a>
<a href="http://s734.photobucket.com/albums/ww342/91CamarosRS/?action=view&current=DSC00120.jpg" target="_blank"><img src="http://i734.photobucket.com/albums/ww342/91CamarosRS/DSC00120.jpg" border="0" alt="Photobucket"></a>
all for this
Old Mar 17, 2010 | 01:13 PM
Car: 02wrx/88 rs
Re: Am i in over my head? rust?!!!!!
it was a kansas car where they use salt on the roads alot. what do u think. looks like a guy tried to cover half of it up with undercoat in a can. and it be blasted and recoated?
anyone who has delt with this help!!!!
Old Mar 17, 2010 | 07:04 PM
campin1983's Avatar
Car: 1984 Camaro 'Vert
Honestly its sorta hard to tell by the pics how expansive the rust is.
Pull the carpet and look from there. The story is much more clear from the inside than the underside. Its not uncommon at all to replace the entire floorpan. I forget where you can get them from, but they are available. Its a bit of a pain, but in these cars, its almost a given when you buy a midwestern one.
The real question is if the rot goes up the firewall or into the door sill. If it does, your starting to have some structural questions. If not, I'd say simply strip it, cut out the floorpan (or partial floorpan) and weld in some donor metal.
My last 'bird had rot that went from the door sill, through the floorpan up to the firewall. I tried controlling the rust, but didn't have the right tools at the time. It ended up twisting real bad and was sent to the scrapper.
Good luck! Pull up the carpet and see what you've got. Repost those pics if you want.
Old Mar 24, 2010 | 01:59 AM
jay_d's Avatar
Car: 84 z28
Engine: 355
Transmission: TH350
Axle/Gears: one wheel peel
looked like it had a rocker panel pretty much gone, id be scared to try to put too much power on that. My advise would be to find a sucker and sell it
Old Mar 24, 2010 | 08:15 AM
campin1983's Avatar
Remind me to never buy a car from you!
Old Mar 24, 2010 | 01:07 PM
Car: 02wrx/88 rs
ha ha. well its not a bad car but for i want im not sure. i have a parts car that i can get almost anything off of.
Old Mar 24, 2010 | 05:09 PM
90_firebird's Avatar
You can take the seats and rug out to see how bad it is under there. Then you could cut where the rust/holes are and weld in a new panle of it you have any fiberglass skills, you could lay some fiberglass mat and resin on the inner floor to cover the holes and rust just dont forget to grind the rust off first b4 the fiberglass.
Old Apr 28, 2010 | 02:28 PM
Car: 02wrx/88 rs
well i pulled carpet. not as bad as i thought but somewhat. all in the front seats. nothing in the rear
Old Apr 28, 2010 | 03:14 PM
Twin_Turbo's Avatar
Is it me or does it look like the original floor pan rusted out or was cut out and a new/other one was laid over it and one side was duct taped to seal? That's how it looks to me.
Old Apr 28, 2010 | 03:30 PM
Car: 02wrx/88 rs
lol i hate to admit but the last few owners were very.... not smart?
Old Apr 28, 2010 | 04:07 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Mine is worse and plan to completely replace both of my floorpans and por-15 them. My rust edges up to my pinch welds and have been told this is fine. It will cost me $500 for removal and install. But that's from a buddies buddy so...and all he does is floorpans and sheetmetal work so its literally nothing and has done this before many many times.
HawksThirdGenParts carries them but for $300ea. I have found them for $270ea somewhere else, but maybe our TGO discount will take care of the difference. Also wonder what shipping from HTP would be.
http://www.carsinccamaro.com/chevy-c...ULL/pid-12437/ (LH)
http://www.carsinccamaro.com/chevy-c.../s_text-12180/ (RH)
Last edited by I H8 WWD; Apr 28, 2010 at 04:44 PM. Reason: Added Cheapest Place To Purchase Floorpans
Old Apr 28, 2010 | 04:34 PM
kevmann's Avatar
Car: 89 RS
Engine: 2.8
I redid my drivers floor. I cut out one from a donor car(Partial pan) and welded it in. I did overlap the old pan but I cut out all of the rust and I sealed both sides after welding. Actually, I have a few loose ends to tie up. I have used quite a bit of seam sealer. The car is sitting in the garage until its all sealed. Its definately not a professional clean job but I undertook it to get the experience. I am not trying to make it a show car but I do want to have a decent looking car that is not rusting out from under me. I would say if you dont have any major rust in the front shock tower areas or to your subframe, and have the extra money to put in pans, then go for it. You could sell it and use the money to buy a rust free car but in our area, even if they say its rust free, you will find rust in the usual places.
Kevin
Frozer!!!
Jan 19, 2024 04:55 PM
deracer
Apr 11, 2016 12:04 AM
hemicudakidd
Aug 31, 2015 06:23 AM
Dialed_In
Aug 20, 2015 01:45 PM
