1 running light and 1 high beam not working...??
Old Apr 7, 2010 | 03:22 PM
89rs305-DP's Avatar
Car: 89 Camaro RS
Engine: Built 357 Vortec
Axle/Gears: 3.23 from an '87 iroc
I have 1 running light and 1 high beam not working. Both on the passenger side. I replaced both bulbs and nothing. Any ideas?
Old Apr 7, 2010 | 03:28 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 1 running light and 1 high beam not working...??
Both bulbs?
Headlights
Circuit Operation:
Voltage is applied to the light switch at all times. The light switch includes a self-resetting circuit breaker which opens and closes if the headlight circuit draws too much current. When the light switch is in "Head," the headlight dimmer switch directs current to either the lo beams or the hi beams. Current to the hi beams also flows to the high beam indicator.
Troubleshooting Hints:
If only one headlight doesn't work in both "hi" and "lo", check the ground wiring.
If headlights don't work in just "hi" or just "lo", check headlight dimmer switch.
If headlights flash on and off with switch in "head," isolate short to ground. Operate the headlight dimmer switch to find if the short to ground is in tan or lt grn wires.
If only the "hi'" headlights flash on and off, check lt grn wires for shorts to ground.
If only the "lo" headlights flash on and off, check tan wires for shorts to ground.
If both "hi" and "lo" headlights flash on and off, check the yel wire for a short to ground.
JamesC
Old Apr 8, 2010 | 04:18 PM
89rs305-DP's Avatar
Car: 89 Camaro RS
I dont know much about wiring, so im a little confused. Maybe i should explain better. My passenger running light never works, but the blinker does. Also my passenger high beam doesnt work. I replaced the blinker/running light bulb and the high beam light, but it still doesnt work. Now what should i do?
Old Apr 8, 2010 | 05:23 PM
TheMuskr's Avatar
Car: 89 IROC Z28 Vert
i had a similar issue. turned out to be a disconnected ground.
Old Apr 8, 2010 | 10:39 PM
Camrs89's Avatar
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
I drove my camaro the other day, same problem, let me know what u find.
Old Apr 9, 2010 | 05:57 AM
89rs305-DP's Avatar
Car: 89 Camaro RS
Well im not really sure where to start. Ive had this problem since i got the car. I think ill check the grounds first. Does anyone know where they are grounded?
Old Jan 5, 2011 | 11:04 PM
pooklywang's Avatar
Car: 1984 camaro
Engine: 350, 292 camp cam, 883 heads
Transmission: 350 turbo, 400 torque converter
1984 camaro running lights not working
Ok, so i got a 1984 camaro i am trying to fix up. The diver side head light works fine but the passenger side is dim. The running lights do not come on. The break lights come on, and the reverse lights work as well. I replaced the light switch assembly, naturally i had to pull out the gauge cluster, when the cluster was out the lights worked fine all of them. I put it back together and nothing back to not working. What is going on?? Please help.
Old Jan 6, 2011 | 11:00 AM
white gold 88's Avatar
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
Check ground on that side to rad support. I'd bet that's the problem. Battery on that side adding to corrosion process. JMO
Old Jan 6, 2011 | 03:00 PM
pooklywang's Avatar
Car: 1984 camaro
Does there need to be a ground from the motor to the frame?
Azrael91966669
25
Jun 20, 2017 04:04 AM
Jae992
Aug 27, 2015 09:07 AM
Fronzizzle
Aug 19, 2015 01:36 PM
BBSDesigns
Aug 11, 2015 07:39 PM
Omega
Aug 10, 2015 12:46 PM
