How to fix.
Old Jan 2, 2011 | 04:24 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
How to fix.
Looks like some PO of my car tried to jack up the body behaind front drivers fender. It is crupled and kindof bent in. Can't bolt up fender all the way or put on inner fender. How would one go about fixing this. Could I get back maybe behind kick panel and pound it out? Any help would be nice
Old Jan 2, 2011 | 04:26 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
Re: How to fix.
this might help
https://www.thirdgen.org/forums/body...ng-damage.html
Old Jan 2, 2011 | 04:33 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Re: How to fix.
That helps some. Can fix tab. But on mine the body seems to be pushed in towatds interior of car also
Old Jan 2, 2011 | 05:51 PM
white gold 88's Avatar
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
Re: How to fix.
Need pics. They don't usually get so bad they can't be straightened. That link should help. How does the door shut? If it's okay then it's just the fender.
Old Jan 2, 2011 | 06:13 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Re: How to fix.
Door shuts as well as a 25 year chevy door can. It is the actuallu body of the car. My phone, which is where I do all my internet won't let me post pic on TGO but if someone can give me email I can send pic.
Old Jan 12, 2011 | 02:08 PM
AmorgetRS's Avatar
Re: How to fix.
Here are the pics of the damage
Old Jan 12, 2011 | 09:11 PM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Re: How to fix.
It's still a little tough to tell from the pics but if it's wadded up so bad you can't work it out by hand you may need professional help. At work I'd put it up on the frame rack or use one of the chain pots in the floor and a clamp on the damaged area then put a little downward pull on it and hammer out the wrinkles. It's easy if you have the right tools. .. a little tougher without.
Old Jan 12, 2011 | 09:41 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Re: How to fix.
Ya. That is what I am afriad of. Is there a way to get it from inside the car. I could probaly get it so the fender would line up, but it is also not same distance from inside edge of tire as it is from outside edge of tire. That seems like it will be hard to fix, and probaly cost a little coin.
Old Jan 12, 2011 | 09:43 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Re: How to fix.
You can kindof tell if you look at the wet spot on inner fender and look at crumpled spot at bottom where fender is not bolted on. That is about how far inner fender area is pushed in
HikoriYami
Sep 21, 2015 07:11 PM
CatmanFS
Sep 19, 2015 09:00 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
codys73z28
Jul 23, 2002 01:20 PM
92fire-audio
Jul 22, 2002 05:47 AM
