Nose repair
Old Mar 22, 2011 | 04:10 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Nose repair
I got backed into a few months ago, and now have a crack right were the headlight bucket curves up on the passanger side. I dont really see a need to replace the WHOLE nose since its not a huge crack. Has anyone repaired something like this? What did you use.
Ill post a pic when I get home.
Old Mar 22, 2011 | 04:40 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Nose repair
Don't know the name, but there's special stuff that has to be used - should be able to get at local auto body store or Eastwood.com
Old Mar 22, 2011 | 05:51 PM
HF_monster's Avatar
Car: 86' z28 (died 5/1/11) 76 k10 pickup
Transmission: th350
Axle/Gears: 3.73 open
Re: Nose repair
read the sticky "lets take the guesswork out of plastic repair" it has every thing you need to know in it.
Old Mar 22, 2011 | 06:28 PM
travis401's Avatar
Car: 91 Camaro RS
Re: Nose repair
I read through it and it looked to me like it focused mainly on small repairs. I wouldnt classify this as small..
Old Mar 22, 2011 | 06:53 PM
401kfirebird's Avatar
Car: 1992 Firebird
Engine: LO3 305
Transmission: 5 speed
Axle/Gears: 3.08 limited slip
Re: Nose repair
autozone carries a product by 3M called bumoer repair. its a 2 part epoxy that comes with a fiber mesh for reinforcing and a spreader as well. it can be used for a filler as well as fixing the crack. im using it on my firebird bumper now. seems to work well. you may new 2 packages of it though for that size crack. it runs about $7 per package.
Old Mar 22, 2011 | 07:00 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
Re: Nose repair
I have fixed a lot of bumpers and I have done them ever way I can think of and the only way I have found to fix them for good is to plastic weld them if you dont have a welder you can take the bumper off and take it to a body shop and they can weld it for about $50.00 bucks and you shouldt have no more problems with it good luck
Old Mar 23, 2011 | 08:06 AM
travis401's Avatar
Car: 91 Camaro RS
Re: Nose repair
I work in a body shop part time....usually we just replace bumper covers if theyre cracked that bad....
Old Mar 23, 2011 | 09:26 AM
nosajwols's Avatar
Car: 82 Z28
Transmission: TH350 for now
Re: Nose repair
When all is said and done it is likely cheaper (or not much more expensive) to replace the entire cover. It is not just the labour in fixing the crack but in the prep etc. for paint.
If you just want to fix the crack and not paint it then there are many plastic repair kits out there that work good enough.
Old Mar 24, 2011 | 12:02 AM
travis401's Avatar
Car: 91 Camaro RS
Re: Nose repair
I just pulled the nose off tonight, im gonna take to the shop and see if we cant work some magic on it.
Old Mar 24, 2011 | 12:08 AM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Re: Nose repair
Thats a tough spot to repair. Plastic welding is really the best way to do it.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
ironbmt
Sep 27, 2015 06:00 AM
