help removing driver side GFX 90' RS
Old Jun 2, 2011 | 02:40 PM
cHEVy hEAVy's Avatar
Car: 1989 IROC Z
Engine: 5.0 tpi. stock [for now]
im trying to take my driverside gfx off and i got the 4 screws on the top off than i believe 5 or 6 more from under the car than another 2 screws behind where the rocker emblem would go. now as i try to take it off the only thing not coming off is the rear part of the gfx. feels like its on tight, but i see nothing holding it.. is there something im missing?? i dont want to rip it off and tear it up.
Old Jun 2, 2011 | 03:09 PM
Car: 1989 IROC Z
Re: help removing driver side GFX 90' RS
ttt
Old Jun 2, 2011 | 03:15 PM
Arizona IROC's Avatar
Car: 1989 IROC
Engine: 305TPI
Axle/Gears: 2:73 posi
There is one stud on the back of the gfx. The nut is on the inside under the rear arm rest. Very hard to get to and easy to loose the nut inside the rocker. I recommend the proper wrench (10mm?) and 1/8 inch drive socket wrench with the flexible bendy extension. It wouldn't hurt to put some tar or gum in the socket so the nut wont fall in when you lift it out.
Old Jun 2, 2011 | 03:20 PM
Car: 1989 IROC Z
lol they couldve made that a little easier haha. do i have to remove that whole inside panel to get behind it?
Old Jun 2, 2011 | 03:23 PM
Car: 1989 IROC
Engine: 305TPI
Yes
Be careful of the corners on the plastic interior. You can break them because of the way they interlock.
No, it's not fun
Old Jun 2, 2011 | 03:43 PM
85projectZ28's Avatar
Car: 1985 Camaro Z28
Engine: 5.7 LSX
Transmission: Performabuilt 4L60E
Axle/Gears: Strange 12-bolt 3.73
ya that one was hard to get to for me as well. i just took off one piece of the plastic interior then pryed the other one enough to give my hand room to work in. i barely got to it! save all the screws you take off in a sandwich baggie and label them passenger, driver, etc. thats what i am doing and believe me, it helps! i wish i would have done that with the interior!
Old Jun 2, 2011 | 03:50 PM
Car: 1989 IROC Z
i took off the lower part of the panel under where the speaker is, and i cant even see where to get the nut. looks like theres not much room to do anything. you wouldnt happen to have a picture of that section without the panel would you?
geez, GM likes to make things complicated
Old Jun 2, 2011 | 04:15 PM
Car: 1989 IROC
Engine: 305TPI
It's way down there. There may be some tar paper or insulation in the way but there is an access area. You probably can't get your hand all the way but You should be able to feel it with your finger tips. (add inappropriate joke here)
Earlier GFX were held on in the back by these weird plastic clips that broke real easy. The later type are probably better.
Old Jun 2, 2011 | 07:54 PM
Car: 1989 IROC Z
so to get to that access point do i peel back the insulation?
Old Jun 3, 2011 | 01:16 PM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
Yes.
Here's a kind of blurry picture of the hole's location, I circled it in red.
Old Jun 3, 2011 | 01:23 PM
Car: 1989 IROC Z
Originally Posted by G-reg
Yes.
thanks for all the help guys.
Old Jun 4, 2011 | 06:41 AM
Engine: 5.7 LSX
So did u get it? I can post a pic from the interior if u still need it...
Old Jun 4, 2011 | 10:49 AM
Car: 1989 IROC Z
yeah, i got it off yesterday, thank you man. hows the paint coming along?
Old Jun 4, 2011 | 08:51 PM
Engine: 5.7 LSX
Slowly but surely. U?
Old Nov 20, 2011 | 10:36 PM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
how do you remove the plate under the door that the GFX bolts up to?
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
kyleb24
Aug 15, 2015 08:24 AM
Street Lethal
Aug 14, 2015 08:25 PM
timonator
Aug 11, 2015 09:56 PM
wruiz
Aug 11, 2015 02:59 PM
