84 Z28 to 91-92 gfx swap
Old Jul 5, 2011 | 04:48 PM
dustinlmiller13's Avatar
Car: 84 Z28 Camaro
Engine: 305 H.O.
Transmission: TH 700R4
Axle/Gears: GM 7.625 w/ 3.42 ratio
Hey guys. I've done quite a bit of research on the subject of swapping out the gfx from a 91-92 to my 84 z28, and understand there will be alot of drilling required to get them to fit right. Is there any less work involved in swapping in the gfx from the 85-90 year range? I wanted to see some pictures of some of your swaps to see if thats what I want to do, or just try and sell this one and buy a 91-92. If you show me some pics, I would greatly appreciate it. Any tips as well?
Old Jul 7, 2011 | 11:42 AM
Car: 84 Z28 Camaro
Engine: 305 H.O.
Re: 84 Z28 to 91-92 gfx swap
Bump?
Old Jul 19, 2011 | 04:14 PM
jllong95's Avatar
Man I was wondering myself im looking at getting a 84 and I like the 91-92 gfx better
Old Jul 19, 2011 | 04:35 PM
Car: 84 Z28 Camaro
Engine: 305 H.O.
Hey, I guess I'm sorta gonna answer my own question. I'll update you with pics as I go along doing the swap. Got the back bumper yesterday and threw it on, fit perfect. Still waiting on the front nose and side skirts (part i dread making new holes).
Old Jul 20, 2011 | 02:18 PM
jllong95's Avatar
on the side skirts what holes are you haveing to drill??? and does the front bumper bolt on too??? it looks like it should
Old Jul 20, 2011 | 03:27 PM
7thdarkangel's Avatar
Car: 1983 Camaro
Engine: Missing
Transmission: Missing
Axle/Gears: 9" Ford
The rear bumper and quarter flares are a bolt on. the front bumper is a bolt on(you will need the support to. if i remember right they are different.) and im not sure about the skirts but i can find out for you.
Edit: the quarter flare are bolt on if you already have flares on the car. if you have a base modle or something you will have to drill some holes.
Old Jul 20, 2011 | 07:00 PM
BHicks's Avatar
Car: 1986 Monte Carlo SS Aerocoupe
Engine: L69 305 H.O.
Transmission: 200-4R
i put the 85-90 gfx on an 84 z28 a while back. The nose just bolts right up. I also got the rear bumper cover, quarter pieces, door pieces and rocker gfx and the front chin spoiler. Everything was pretty simple and straight forward and bolted up no problem. The only drilling I had to do was where the chin spoiler attatches to the bottom of the fenders and made a new mounting plate cause the old one the studs broke off.
I sold the car shortly after.
I now have a 89 iroc im putting back together and i put new fenders on it and they arent drilled for the chin spoiler but its not hard just take your time.
If you have the basic common sense to do the bolt on swaps then drilling a couple holes wont be a problem.
As for the nose, i bolted it up with the header panel and all still intact. Hardest part is there it attatches to the fenders is a little pain in the tail to get to the nuts
Old Jul 22, 2011 | 02:04 PM
ACLerok's Avatar
Car: 84 Camaro Z28
Engine: 305 H.O.
OP, do you plan to sell the front spoiler from your 84? I have an 84 z28 without a front spoiler and would be interested in purchasing yours.
Old Jul 22, 2011 | 03:09 PM
Car: 84 Z28 Camaro
Engine: 305 H.O.
Yeah, I sure do. I was actually getting ready to post in the parts for sale, but was waiting till my front bumper came in to take mine off. No idea yet what I want for it so just make me an offer in a pm and ill get back to you. Thanks for the responses fella's!
Old Jul 24, 2011 | 10:44 PM
ACLerok's Avatar
Car: 84 Camaro Z28
Engine: 305 H.O.
Could you post a pic of the bumper and spoiler?
Old Jul 25, 2011 | 01:43 AM
Car: 84 Z28 Camaro
Engine: 305 H.O.
Sure can, tomorrow while its still on the car! Just got my new one from ups yesterday so I'll update some pics for you. Any trick to posting pics on the forums?
Old Jul 25, 2011 | 09:30 AM
ACLerok's Avatar
Car: 84 Camaro Z28
Engine: 305 H.O.
Sounds good. There really arent' any tricks. If the pictures are on your computer you can add them as attachments to the post. As long as you don't do the "quick reply" when replying, below the area where you type your message is an "Additional Options" area with a button for "Manage Attachments". Just use that.
Old Jul 26, 2011 | 03:02 PM
Car: 84 Z28 Camaro
Engine: 305 H.O.
Here is a picture of the front bumper and spoiler. No problems at all with either of them (no broken tabs etc.). The only thing wrong that could be considered a problem is the black primer is starting to spider crack. No rips or tears in either of them.
Old Oct 5, 2011 | 02:07 AM
Zed28's Avatar
You will have to change the park lamp sockets to the newer style a well. I'm in the process of installing the 91-92 package
Old Dec 18, 2011 | 06:31 PM
firbster's Avatar
Car: 84 Z28,03 GSXR1000,07 RMZ 250
Engine: H.O. L69
Transmission: 5spd
Axle/Gears: 3.73 possie
hey Zed28 , im about to undertake your same change, 84-91 change over, so how did it go and what problems did you run into ? can you post some pics ?..
Old Dec 19, 2011 | 04:53 PM
nosajwols's Avatar
Car: 82 Z28
Transmission: TH350 for now
I have an 82 which is the same as an 84 AFAIK. I have 86 ground effects on the car but I kept the 82 front bumper (and 82 chin spoiler).
There were a few holes that needed to be drilled (mostly where the old ones were using the old style GM molding tabs/clips). You also have to replace the rear bumper cover.
Old Dec 19, 2011 | 05:57 PM
SylusMk2's Avatar
Car: 83 Berlinetta
Engine: 2.8
its ashame your not closer i would trade you
Frozer!!!
Jan 19, 2024 04:55 PM
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
LilHot
Exterior Parts for Sale
20
Apr 1, 2016 04:45 PM
silverstang84
Exterior Parts Wanted
Sep 21, 2015 08:05 AM
LilHot
Aug 19, 2015 10:02 AM
