Help - Multi-function Lever messed up!!!
Old Oct 19, 2000 | 03:31 PM
Dan91Z28's Avatar
Hi All,
My multi-function (turn signal, cruise, etc...) lever doesn't work to dim or brighten the lights any more. Do i have to pull the steering wheel to get it out or can it be replaced with the wheel on? Anybody have any experience doing this? I was also thinking of just doing the floor dimmer idea posted elsewhere by macgyver. Anyone else have good luck with that? Looks cool to me i dunno. thanks!
Old Oct 19, 2000 | 08:28 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
There is an adjustment on the column for the dimmer switch, the lever doesn't do anything but put push a rod down to the switch.
This is located on the left side of the column...below the mounting bolts for the column. (its kinda toward the top)
Does everything else on that lever work??
I would adjust the switch. At worse case you have to buy a new one.
No, you don't have to pull the wheel.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
[This message has been edited by Engineboy (edited October 19, 2000).]
Old Oct 20, 2000 | 07:48 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
My stalk switch broke in my 89RS. If I remember you push the whole stalk in and twist and it pops out of the column.
Rob P
89RSconvtZZ4TPI
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Oct 23, 2000 | 09:30 PM
Dan91Z28's Avatar
Thanks for the tips, i found the switch the rod is supposed to be moving on the steering column. But of course the rods not moving so it must be broken by the multi-function gizmo. Everything else off the multi-funct. works fine. So now i just gotta pull the m.f. and see where its broken.
Dan.
Old Oct 27, 2000 | 08:18 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
Dan - I don't know how far you've gotten into it yet, but it may not be moving because of the switch being messed up and not allowing it to. I'm just tossing this out here... I had kind of the same problem for a LONG time and never fixed it cause (1) I didn't know how and (2) they said it was a bunch of $ (labor) to fix it. Then one day a long time ago before this board went down that time, someone els had the same problem and that's where I basically figured out I could fix the m/f myself. Anyhow... getting to the switch really isn't too easy. You'll need to drop the lower dash cover, of course, but you'll have to drop the steering column, as well - just a couple of nuts. But that switch is like in a hard-to-get place. Hopefully it's just the switch messed up, or even better, loose. All that was wrong with mine is that is was out of adjustment. I popped it loose, adjusted it, and tightened her down - been good to go ever since. Good luck - I hope it's fairly easy for you...
KAM
Old Nov 3, 2000 | 08:45 PM
amagin86's Avatar
I've got two camaros with bad mfswitches. one is wipers, the other cruise thats malfunctioning. i figured out how to twist an pull out the lever, but i cant get the darn wires to come out so i can unplug them. do i have do drop and skin the column for this. it's been awhile since i messed with this issue but i'd love to fix it. also how much does a new lever cost from gm?
thanks
alex m
Old Nov 4, 2000 | 01:26 AM
Dan91Z28's Avatar
Hi All,
thanks for the tips, in reply to alex the wires are plugged into a connector somewhere around the base of the steering column. Once unplugged they just pull out through the top but its a good idea to tie a string to them so you can put them back in w/out too much hassle.
Old Nov 4, 2000 | 01:32 AM
amagin86's Avatar
somewhere around the base, huh? i'll check it out
thanks alot!
alex m
columbia mo
F-body-fan
Jan 12, 2023 01:49 PM
Ed1LE
Sep 30, 2018 09:14 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
ndndndnd
Sep 28, 2015 08:00 AM
tattmann
Sep 27, 2015 05:20 PM
