switching front ends
Old Nov 6, 2000 | 03:24 PM
dcargill6's Avatar
Does anyone know if you can put a 92 front end on a 1982 Z28.
Old Nov 6, 2000 | 03:27 PM
Duffster's Avatar
Car: 2001 Camaro Z28/1995 Camaro Z28
Engine: just a little 5.7(LS1-320/340 RW)
Transmission: SMOOOOOOTH T-56/Auto. . .
Axle/Gears: 3.42 and 2.73
yes you can...same bolt holes and fender alignment holes.
Old Nov 6, 2000 | 05:56 PM
S92RS's Avatar
Yep Duffster is right. It's not too hard either. I made my 84 Z28 look like the newer style. I swapped on the nose, ground fx and the rear bumper from an 89 . It all bolted up like it was supposed to.
- the 92 RS is gone..
- 1984 Z28 with 89 bumpers and ground effects.
- 355 with ported World S/R Torquer Heads, 214*/224* .471/.496 lift cam, Crane 1.6 Full Roller Rockers, 2500 non-lockup stall converter, Holley 750 carb, Edelbrock Performer intake, Hedman headers with custom 3" Flowmaster exhaust, Lakewood LCAs, Powertrax Locker with 3.23 gears.
- http://s84z28.fbody.com
Old Nov 6, 2000 | 07:04 PM
dcargill6's Avatar
alright thanks guys. This is exciting news to hear.
thanks a lot
Old Nov 7, 2000 | 10:43 PM
Yellow Camaro's Avatar
Are all Camaro front ends essentially 100% interchangable? I need one for my 87 Sport Coupe, and I can get one for cheap off an 82 Berlinetta, but wasn't sure if it would line up. It's older but I actually like the look about the same. It has room for foglights which mine doesn't, and the license plate bolts right to the car rather than that plastic holder mounted on the front.
Old Nov 9, 2000 | 12:23 AM
btt....anyone?
Old Nov 9, 2000 | 01:06 AM
Duffster's Avatar
Yes Yellow, it will fit, but to warn you, the nose looks different...look at the turn signal recesses...those aren't on the 87 nose... looks different... 87...flat...82...recessed...looks different.
NOT GONNA DO IT...WOULDN'T BE PRUDENT...
Old Nov 9, 2000 | 05:04 PM
Yeah, thirdgen noses constantly changed as they got newer. I'd still rather have an 82 for almost free off of a friend, then an 87 for $150 at the boneyard. And like I said, in some ways I believe it looks better. I rather like the way the license plate bolts right to the nose, and there's an opening for foglights on either side. The 87 just has a one-piece black grill across the front, with a plastic license plate holder attached to it. It doesn't matter to me, I just want my car to look nice again without spending an arm and a leg. What did you mean by "Not gonna do it, wouldn't be prudent"? Thanks for your help/suggestions.
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Mutillator
Exterior Parts for Sale
Oct 1, 2015 06:05 PM
bellez77
Sep 5, 2015 08:39 PM
