Rust... /:
Old Jul 18, 2012 | 08:39 PM
orangek's Avatar
Rust... /:
So I have some rust on the inside part of the trunk near the rear bumper when closed. I need to get some opinions on it on how to fix and get rid of it. It's pretty bad rust and I need to get rid of it before it spreads even more. Here are some pictures:
Old Jul 18, 2012 | 09:05 PM
peterc005's Avatar
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
Re: Rust... /:
Hit it with a wire brush, sand it smooth, then coat with a rust inhibiting paint like POR 15.
Old Jul 18, 2012 | 09:09 PM
orangek's Avatar
Re: Rust... /:
You don't think I'll have to cut that section of the car and then patch in a new one? That's honestly what I thought needed to happen. hopefully it doesn't
Old Jul 18, 2012 | 09:12 PM
SolarGoldRaptor's Avatar
Car: 1984 Pontiac Firebird Trans Am
Engine: V8 5.0L HO (L69)
Transmission: B&W T5
Axle/Gears: 3.73 limited slip
Re: Rust... /:
From the looks of it, it seems you won't need to make a patch. Maybe some small chunks of metal will go with the wire wheel, but not enough to require new metal. Just do like peter said, clean the area as much as possible, if you manage to go to a perfectly clean bare steel, shoot some epoxy primer on it then paint it. If not, apply some POR15 or Zero Rust, the sand and paint.
Old Jul 18, 2012 | 09:14 PM
orangek's Avatar
Re: Rust... /:
Alright thank you. Since I have of tomorrow I'm probably going to do it. Is POR15 an automotive only thing that I need to get at like an autozone? Or can I get it at a wal-mart, sears, etc.
Old Jul 18, 2012 | 09:26 PM
peterc005's Avatar
Transmission: T700
Re: Rust... /:
Do a Google search, there are other similar products to POR 15 that will work fine.
Also, make sure the are is perfectly dry and clean before painting it.
Old Jul 18, 2012 | 09:37 PM
orangek's Avatar
Re: Rust... /:
I'm moving it into the garage tomorrow morning before I go and get the stuff I need for it, so I can dry/clean it. Thats probably another reason the rust has gotten so bad, I've had it outside for awhile while its raining stupid move
Old Apr 9, 2013 | 05:44 PM
Daves82's Avatar
Re: Rust... /:
Wow these boards are funny. I don't see any really bad rust, heck I see nothing to worry about! (Actually I would wire wheel it then seal prime and paint it). But I'd love to have anything with that little rust around here!
Old Apr 10, 2013 | 11:21 AM
psychedelic_leg's Avatar
Re: Rust... /:
duct tape and cake bondo on it.
on a serious note. just a wire brush to bare metal and primer+paint. to those saying "use por", yeah, por only sticks well to rust as far as I know. but up to you.
Amillionoh7
Aug 7, 2015 01:24 PM
FJA1791
Exterior Parts for Sale
16
Nov 1, 2014 10:34 PM
Brother Al
Jul 18, 2013 10:53 AM
cc+ca
Firebirds Wanted
Jan 12, 2013 07:06 PM
12SecondTA
Nov 5, 2006 11:31 PM
