87 Camaro Sport Coupe.....No door keys.... how do i open the hatch?
Car: Too many!
Hello, I just bought an 87 Camaro sport coupe but it doesnt have door keys. How do I open the hatch? I dont think there is any buttons to try to open it. Any help is grealty appreciated! Thanks!
Car: 83 Z28/L69
Engine: L69 305H.O.
Transmission: 6spd T56
Axle/Gears: 4.10 LS 4th Gen
Re: 87 Camaro Sport Coupe.....No door keys.... how do i open the hatch?
You can remove the passenger side door lock, there is a key code for the door key on the lock. Take that key code to locksmith and he can cut you a with the code for 5 bucks or less.
Know that is some good information.
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Take your vin to a gm dealer and they will get you keys!!!
Car: Too many!
I tried to do that, I actually work at a Chevy dealer and we can't make keys that far back based on VINs
Car: 83 Z28/L69
Engine: L69 305H.O.
Remove the door panel, there is a little U shaped clip holding the lock in. It just slides out after you remove the lock rod. Be careful when removing the lock rod, the plastic clip can be brittle.
FYI: Its a 4 digit code.
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
I thought they had a a hatch release switch in the center console,there is a my camaro anyway.
Car: 83 Z28/L69
Engine: L69 305H.O.
Car: 89 IROC Z28
Engine: 357 TPI
Oh, too bad it is very handy. So the OP can't lock his car either?
Years ago I mean a lot of years ago I lost the keys to my door. I locksmith made a new one by sticking a blank in the lock turning it until it made marks, ground it down repeated it a few times like magic I had a new key.
