Parking Lights
Old Mar 8, 2001 | 11:18 AM
PopaPork's Avatar
Parking Lights
I know everyone has seen the new vettes and camaro and even bird how bright their parking lights are. Anyone know the bulb that they got in there and if it would fit on a 3rd Gen? thanks.
89 Rs Camaro 305 TBI
Air Intake
K&N air filter
80 Series FlowMaster Muffler 2.5 inch Cat Back
BFG 235/60r15 (soon to be 25th Anniversary rims with 235/50r16)
Apperance: Black gray pinstripe. Black interior with Gray center piece in seat. Blue Gauge lights and 2 Blue neons under dash Board.
90 Iroc Checkerd Tail lights
Iroc Foglights
System: Pioneer 5200 Head unit Polk 3 ways up front and in the back. Kenwood 300 watt amp pumpin a 8inch JBL GT
Old Mar 8, 2001 | 12:28 PM
CamaroZ_85's Avatar
they're probably halogen bulbs...i thought maybe sylvania would have an online automotive catalogue but they dont. anyway, many of the newer cars have halogen bulbs on the outside and if this is true for the vettes camaros etc the style they have wont fit.
350, Comp 262, Edelbrock Performer intake 600 cfm carb and exhaust, headers
-JVC, Eclipse, Pioneer, MTX, Phoenix Gold, Planet Audio
Old Mar 8, 2001 | 01:57 PM
Mo's Avatar
Mo
there was a thread around here the other day talking about making thirdgen parking lights brighter, its probably in here or in appearence...
It said something about there being a brighter light bulb you could use, but that it runs too hot, I don't recall what was finally decided.
HTH
90 IROC 5.7l (L98)
ram air, K&N's, air foil,Flows
LIKE A ROC
Old Mar 8, 2001 | 06:58 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
I also heard that you can reverse the wires (put the positive on the negative and the negative on the positive) and it makes them brighter. The drawback is the turn signals don't work in front, only in back and on your side markers. I was always wondering if putting the orange lenses on (from the older third gens) with bright, clear bulbs would make them brighter. But I dont know if the orange lenses would fit or if it would even work. If you figure out something that works, let me know.. I've always wanted mine as bright as the newer cars. Good luck.
1992 Camaro RS
305ci automatic, all stock til I get some cash.
My 1992 RS
Old Mar 9, 2001 | 09:07 AM
Fastcamaro87's Avatar
93 newer camaros use bulb #2357 i looked at it and it looks like it would plug in to our parking lights but i havent tried it. let me know if anyone does this..
87 IROC-z 305 TPI 5spd Borg warner 9-bolt 3.45 posi 4 wheel disc,8.8 Accel wires , bosch platinum +4 plugs,gutted air box,k&n oil filter,synthetic oil 10w30
Old Mar 9, 2001 | 11:18 AM
jobryan26's Avatar
Yea I'e thought of that. I would like to make my front turn signals as running lights/turn signals. So when the light are turned off the brighter filament would be on and then when I turn on the lights they function as normal. Any body know how?
'87 Trans Am
305 TPI:
160 Degree Theremostat
Accel 300+ 8.8 Racing Wires
Accel Super Coil
Bosch Spark Plugs
Custom Ram Air with K&N
Old Mar 10, 2001 | 10:36 AM
Rough84Z's Avatar
I believe that you are referring to the Daytime running light modules that are on the newer cars, but I could be wrong. I don't remember exactly where I found it but, I have printed out the directions on how to do the conversion. Do a search on google.com for 'DRL' and you should find some useful information.
BTW- The directions that I found required installing a toggle switch to change from DRL mod to normal mode to insure proper operation of the lights. It would be simple enough to install a relay in it's place so that the lights would automatically operate in normal mode when the headlights are on.
[This message has been edited by Rough84Z (edited March 10, 2001).]
Old Mar 10, 2001 | 11:04 AM
Car: 1989 IROC-Z
Engine: 383 stroker
Anyone find the article? I tried "DRL" and "Daytime Running Light Conversion" and "DRL Conversion" but all I can find is instructions for a RX-7. If anyone finds it, post the address. Thanks.
1992 Camaro RS
My 1992 RS
Old Mar 10, 2001 | 11:25 AM
Rough84Z's Avatar
Ok, I got off my lazy *** and went to my car to get the print out. The article is located at:
http://www.swcoast.net/~bcdavis/imag...e_made_drl.htm
Old Mar 10, 2001 | 12:24 PM
Car: 1989 IROC-Z
Engine: 383 stroker
I saw that too but his car is a 1995 Z28. Will that same set up work with a 92 or any other third gen? I'm sure it will, but I'm not great with electronics so I don't wanna blow my car up.
1992 Camaro RS
My 1992 RS
Old Mar 12, 2001 | 12:29 PM
jobryan26's Avatar
Yea and if you don't use the toggle switch will they still work like the daytime driving lights?
'87 Trans Am
305 TPI:
Accel Super Coil
Bosch Spark Plugs
LittleFranks
Sep 17, 2015 12:22 PM
Jk_Under
Sep 2, 2015 10:59 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
