Anyone get water on pass front floor?
Old Apr 17, 2001 | 04:43 PM
ScreaminDeamin85Z's Avatar
i have no idea where its coming from.its really wierd because i have floor mats and they arent wet just the carpet below the floor mats. i pulled the carpet up and the uderside it soaked and there is water resting on the floor pan. this is the only spot that does this, and it cant be fromt he t-tops unless water jumps when it lands. does anyone else have this problem? both of my camaros did this but i still havent figured it out yet. anyone?
Brandon
"ScreaminDeamin 360"
350 60 over, TRW forged 9.83:1 pistons,Hooker Comp headers, crane cam 216/228 .484/.512, crane 1.6 RR's, ported plenum, home made ram air, 24lb SVO injectors, crane AFPR, all going through 3 inch mandrel pipe and a flowmaster.
New project-89 IROC
Soon- 6 speed, Pro 5.0 shifter and 4.10's
http://users.argolink.net/bvana
http://ScreaminDeamin.cz28.com
Old Apr 17, 2001 | 05:04 PM
cvpde37's Avatar
Sorry to say it sounds like you have a leaky heater core. It's a problem that won't go away until you replace it.
1984 Z28 350
Never argue with an idiot, they'll just bring you down to their level and beat you with experience
My Web Page
Old Apr 17, 2001 | 05:41 PM
it only gets wet when it rains though.
Brandon
New project-89 IROC
Old Apr 17, 2001 | 07:18 PM
farm-kid/88camaro's Avatar
Hey, i got the exact same problem. I assume that its leaking down a window seal. That would be my first guess anyway. The first time i saw it i thought it was the heater core too...was relieved to find it wasnt
Old Apr 18, 2001 | 04:10 AM
KenGTA88's Avatar
I have two firebirds and I have the same problem with both cars. It occurs only when the car is parked and it rains for long periods of time. One of my cars I found the leak on the passenger side. The water comes in from the wiring to the power antenna behind the kick panel. This is why the top of the carpet doesn’t get wet because it is flowing under the mat and then puddles on the floor until it seeps through the carpet. I just put a bead of silicon around the edges of the wiring harness and its fine now. My other car on the other hand leaks on both sides, same situation but I can’t figure out where it’s coming from.
Old Apr 18, 2001 | 08:29 AM
purpleworm's Avatar
I had the same prob. It would go even with the hump in the floor. Mine rotted on the seam in the floor. It was coming in under the fan box in the engine compartment. I had to do some creative body work.
91 Z28 Camaro
305 TPI
700R4 with 2000 Stall and shift kit
Old Apr 18, 2001 | 09:08 AM
sweet i saw that by the antenna and had put a bead of silicon around in just incase, and i also saw a hole just below where the front window meets the body.
Brandon
New project-89 IROC
Old Apr 19, 2001 | 07:20 AM
Chris 611's Avatar
Just this weekend I had a similar problem. About a half gallon of water on the passerengers side floor. It wasn't antifreeze, so I knew the heater core didn't leak. I put a garden hose just above the wiper and let it flow. Sure enough it was coming in through the bulk head where the electrical harness passes through just behind the kick panel. Hope this helps.
Old Apr 19, 2001 | 09:25 AM
Pino91Formula's Avatar
I have the same problem , everytime it happens i notice the door panal has a trail of water right in front of the cup holder, I have been driving my self crazy trying to figure out where it comes from , but the thing is i only remeber anout it when it rains. Ill have to check out the bulk and the wiring holes
Old Apr 22, 2001 | 11:44 AM
craig's Avatar
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
i had the same problem and it was coming from a hole in the inner fender. only noticed it while putting on my subframe connectors.
Old Apr 25, 2001 | 10:20 PM
Belker's Avatar
I recently noticed water (after a few rainy days) on my drivers side floor. I crawled under the car and, sure enough, a hole had rusted through my floor pan. Check your floor pan for a hole.
Old Apr 25, 2001 | 11:14 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
I haven't done much digging on the 3rd gen, but this was a common problem on 1st gens. There was a drain hole under the cowl panel that would get clogged by leaves or debris. When it rained, the water would accumulate until it drained into the car. Check for clogged drain holes under the cowl, if there are any.
87 IROC 350 TPI with less than 10k original miles
www.users.uswest.net/~smoyer/iroc.htm
Northstar Camaro Club of Minnesota
Old Apr 30, 2001 | 12:59 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
I had a leak just like yours; It was indeed from the T-tops. The water follows the T-top weatherstrip to the front windshield filler, where it drops through some faulty caulking into the plastic filler. The filler funnels it to the right-most kickpanel where it drains onto your floor.
You can easily check to see if this is the case by removing the plastic filler (one screw and two press-in interior plugs) and hosing down your T-top with a garden hose. If it's leaking, you'll see it drip near where the T-top locks into place.
Daniel Burk
http://www.isthq.com/~dan/fcar.html
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff. PST suspension, Braided stainless brake lines, Koni struts, 11-inch rear disks,Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Turbine Technologies 2500 stall converter, underdrive pulleys, Crane Hi-6 & more.
1.05g skidpad verified.
New best E/T! 14.039 at 100.82 MPH in 41 degree air at Stanton, Michigan.
Old Apr 30, 2001 | 04:34 PM
burntblues's Avatar
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
I had the problem and it wasn't the t-top but the black support piece that the tops lock into. If you decide to work on the tops take that bar out while you have it apart and use an entire tube of silicone on it, it'll squish out, thats just enough...
Mike
Old Feb 24, 2008 | 08:32 PM
allgood's Avatar
Car: 92 WS6 Trans am convertible
Engine: ls 6.2
Transmission: 4l80
Axle/Gears: 2.73's
Re: Anyone get water on pass front floor?
i believe i have the same problem i can't see where the water is comming from i have 2 trans am convertible and its not the top or anything like that, its just the front pass side floor and its not all the time sometimes when it rains, snow and it melts or when i wash my car sometimes.
so i was wondering how did you solve your problem
Old Feb 26, 2008 | 04:37 PM
Grizzle B's Avatar
Car: 1984 Camaro Z28
Engine: '92 LT1
Transmission: 700R-4
Axle/Gears: 3.73 factory posi. disc brakes
I had a whole puddle in mine once
Old Feb 26, 2008 | 07:44 PM
allgood's Avatar
Engine: ls 6.2
Transmission: 4l80
Axle/Gears: 2.73's
same problem but i believe its coming in at the bottom right corner need help i can see alot of dirt and other mess between my fender and door jam
i how did you fix the problem
Old Feb 27, 2008 | 04:04 PM
allgood's Avatar
Engine: ls 6.2
Transmission: 4l80
Axle/Gears: 2.73's
[quote=ScreaminDeamin85Z;404442]sweet i saw that by the antenna and had put a bead of silicon around in just incase, and i also saw a hole just below where the front window meets the body.
what did you do about the hole just below where the front window meets the body
so how did you fix the problem
what kind of hole and what did you do about it
what is the cowl
69 Six Pack
Oct 5, 2015 07:51 PM
Polo Z03
Sep 10, 2015 06:43 PM
wruiz
Aug 11, 2015 02:59 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
