why is my car making that noise?
Old Jun 19, 2001 | 02:46 PM
92 z28's Avatar
hey, i have a 92 camaro, everytime i turn my steering wheel all the way to the left, it seems like something around the front left tire is making this weird continues poping noise, i have no idea what this may be. if anyone mite have a clue i would appreciate the feedback. thanks
dozer80464@aol.com
Old Jun 19, 2001 | 04:59 PM
fast.as.fuc's Avatar
sounds like somthing to do with your front axel
Old Jun 20, 2001 | 12:48 AM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
I have wide tires on my car, so the tire rubs in the wheel well when I turn. It rubs on the mud flaps. I don't know if that is your problem, but it coul be a possibility. You never mentioned if it was when you were moving or not.
Old Jun 20, 2001 | 12:58 AM
bubbz89's Avatar
Car: 1990 RS
Transmission: TH-350
front axel?
Old Jun 20, 2001 | 01:47 AM
Jiffy's Avatar
Mine does the same thing...its done it since I bought the car 3 years ago. It never hurt anything that I can tell. My fix was to not turn the wheel al the way over.
Old Jun 23, 2001 | 07:57 AM
CloudIROCZ28's Avatar
Our cars don't have a front axle.......ummmm yea
1987 IROC-Z
G92, LB9 305 TPI, 3.23, Bright Red with Carmine Interior, Pioneer DEHP47DH CD deck.2 JBL DS645 4*6 (F).. 2 JBL DS965 6*9 (S).. Soon to get new 305 TPI
Old Jun 24, 2001 | 02:56 AM
bubbz89's Avatar
Car: 1990 RS
maybe he has a 4x4.
Old Jun 24, 2001 | 11:59 AM
89rsRod's Avatar
your front wheel bearings probably need to be greased
Old Jun 24, 2001 | 12:57 PM
robbob's Avatar
Could be worn out bushings.
Or could be damaged tie rods.
Old Jun 25, 2001 | 07:11 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
The caster in your axles could be set too far back or forward *Where the wheel sits compaired to the fender wall* If it's set too far either direction, when you turn all the way, the tire will rub on the back or front of the fender. Park it, turn the wheel one way, and go look. Mine does it, I need new struts before I can send it to the alignment shop.
Old Jun 25, 2001 | 07:14 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
ball joint maybe???
B_Dubya
Aug 26, 2015 05:09 PM
BlackBoulder
Aug 11, 2015 11:15 PM
hokis
Aug 9, 2015 03:57 PM
BrianI
Aug 9, 2015 11:52 AM
