poping the hood problem
Old Jun 30, 2001 | 12:17 AM
92 z28's Avatar
hey guys, i have a situation that must be solved once and for all. well i know many of my fellow thirdgen buddies all have the same problem. everyone has a problem with poping their hood. after pulling the hood cable thing the hood doesnt pop up. you ussually have to play with it and try to get it to pop up. now i tried rasing the bumbers but that didnt help much. now if anyone knew what the solution is, or has any tips, i would appreciate it. thanks
dozer80464@aol.com
Old Jun 30, 2001 | 12:26 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Grease the latch & striker
The mind is like a parachute, it only works when its open
Old Jun 30, 2001 | 12:27 AM
FiReBReTHa's Avatar
lol, your funny. correction. GM is funny. i bet theyre still laughing about it as ajoke,
for now, i pull a quick move from happy days. and im on my ways...
EEEEhhhh...?
im poetic... and pathetic.
this post/reply, is over.
yes, id like to fix too. bet you is like, adjusting where the hood hoop is and the catch. no idea man.
91 FireBird 305 V-8
Edelbrock Catback, Fourth Gen Console. i have six cupholders. all for starbucks!
ghetto rigged cold air intake,
"My G/f Once Wanted To Break Up Because Of Competition With The Car."
GheTTo Riggers INC.
We Make Mcgyver look Like Crap
God Created The Earth, And Then Turned Up The Bass
Old Jun 30, 2001 | 09:53 AM
TransAm383's Avatar
I had an 84 Trans Am for a little while that had the same problem. You would pull the lever, hear it release but the hood wouldn't budge unless I slammed the door real hard. Then it would pop up just fine.
Old Jun 30, 2001 | 10:56 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
HOODPINS!!!!!!
Old Jun 30, 2001 | 12:39 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
IMO grease only contributes to the problem by collecting debris and gumming up the works. Two important things. 1) The condition of the hood latch bar. If it is worn you will have problems, replace it. 2) The alignment of the bar with the latch assy. If the hood has been removed or the car was in an accident it may be out of alignment. Loosen the two bolts and adjust the bar until it releases properly. As far as lube goes, I recommend thoroughly cleaning the latch assy and spraying it with dry moly lube. Good luck, Lon.
90 RS Convertible
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
[This message has been edited by lonsal (edited June 30, 2001).]
Old Jun 30, 2001 | 01:22 PM
blackstripes's Avatar
WD-40.
Old Jun 30, 2001 | 08:16 PM
Tyler-88's Avatar
yeah, all i did was drop about half a dozen drops of oil on the spring and all the other goodness down there, than played with the linkage for abit and it all works fine now
Old Jun 30, 2001 | 10:27 PM
One Eyed Jack's Avatar
I just did it today a few hours ago with a few doses of WD-40 and it works great now.
1992 Pontiac Firebird (stock)
- 305ci V8 TBI / Automatic Trans / Every option, excluding leather
- Killer car audio system:
  • Aiwa CDC-MP3 head unit
  • Rockford Fosgate 360a2 amp
  • pair of 12" MTX Thunder 5000s in a custom box
  • Pioneer 3-way 6x9s, soon to add more more more!
Old Jun 30, 2001 | 10:29 PM
camaro6spd's Avatar
yep, WD-40 and a little grease on the latch and the pin that goes into the latch and then adjust the hood bumpers. Hood would not budge before, now it pop up like it was new.
Old Jun 30, 2001 | 10:58 PM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
OK, several things.
First, clean the latch with a good brake or carb cleaner and lube it. Make sure it works freely and lube the cable. Then pull the spring out a LITTLE BIT to give it some more tension. Also make sure the latch is aligned. The only thing the 'bumpers' are supposed to be used for is making sure the hood doesn't vibrate or move around while closed. They should be up snug, but not tight (so it doesn't bend or deform), against the hood.
Hood struts play a BIG role in this. A heavy hood won't want to open with weak struts. I'm sure one (usually all)is the problem.
Street Lethal
Apr 30, 2019 12:14 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
Bert87
Aug 23, 2015 03:50 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
