dent on drivers side door
Old Mar 18, 2013 | 09:31 PM
the blue one's Avatar
Car: 1988 base
Engine: 305 tbi
well. i bought this 88 camaro with a few long dents on the door. most of them are dings that i can just bondo, but there is a lare gone that i can;t seem to handle. i tried going from inside the door, but i cant get in there enough to push it out enough to really make a difference..... i also havent completly taken off the door panel yet. i will be to replace the weather stripping, will i be able to acess the bottom of the door to easily pop out the dent, or should i go hard with bondo and hope and pray it doesnt look like sombodies butt
Old Mar 18, 2013 | 10:10 PM
dctrouant1995's Avatar
Car: 1988 pontiac trans am
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Re: dent on drivers side door
Pics would help, but depending where its at, you may be able to hit it out a little bit (you do not want to make a high spot), then bondo it, block it, prime it, block it and then if there is any low spots put glaze putty over that to smooth it out completely, prime it and block one more time. and if you did everything correctly it should come out really great
Old Mar 18, 2013 | 10:40 PM
lmidden's Avatar
Car: 1987 camaro sc
Engine: lg4 305
dont go crazy with bondo all you will have a couple years down the road is massive cracks that will make you you just left the dents alone
Old Mar 19, 2013 | 01:03 PM
2007xl50's Avatar
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
I'm going to do the same on the drivers door on my RS, the key is not to cake the filler on too deep, you can always go over it again if need be. I have seen alot of awesome bondo jobs and alot of bad ones as well-looks like plaster just slapped on there.
Old Mar 19, 2013 | 01:20 PM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Yeah... go easy on the Bondo.
If you build it up too much, it takes on a life of its own.
Old Mar 19, 2013 | 01:25 PM
Twin_Turbo's Avatar
WTH?
Old Mar 19, 2013 | 09:14 PM
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Also make sure to use a good guide coat on the primer to find any low spots and pin holes! I recommend this: http://www.summitracing.com/parts/smm-38203. Use it all the time at work and love it. Make sure when you do your blocking to use a long hard block every time. 80 grit on the bondo, 220 the primer, 180 the putty, 400 the primer. Then get a small flexible block and wetsand with 600. Make sure to use a good urethane primer. I recommend this: http://www.summitracing.com/parts/smm-ml010.
For the hard block: http://www.summitracing.com/parts/ar...4402/overview/. For the soft block: http://www.summitracing.com/parts/mgc-sb-3. For sandpaper, use quality stuff, 3m is all right, but spend a little more and getter better quality sand paper. Any paint/body supplier should have the items I listed. Make sure to get good quality bondo and putty. As far as hammering out the dent, use a small hammer on the inside of the door and hard thick flat piece of metal on the outside to prevent high spots. Good luck!
Old Mar 19, 2013 | 09:19 PM
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Like 2007xl50 said, u can bondo, prime it and block (you can do that as many times as you need, just dont over do it), just don't cake it on there the first time (or anytime for that matter, just even, thin coats) and make sure you let everything dry/cure completely before you block it
Old Mar 21, 2013 | 09:14 AM
2007xl50's Avatar
Engine: LB9/3.1
One more thing is before you bondo make sure to sand all the paint off over the area and then a tad bit past it that you are going to mud so it gets a nice stick, It's ok if out get a tad bit of mud on the surounding paint as it will be sanded off anyways when you level it all out. Remember the key is to not have a transition from the metal to the mud back to the metal.
1992 Trans Am
May 10, 2023 07:19 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
GVMV
Aug 16, 2015 07:08 PM
kyleb24
Aug 15, 2015 08:24 AM
timonator
Aug 11, 2015 09:56 PM
