gmc truck door handles
Old Jun 21, 2013 | 05:04 PM
Cadaver_Puncher's Avatar
Car: 92 Camaro rs ( mostly stock for now
Engine: 3.1 v6
Transmission: 700r4 with a b&m megashifter.
Axle/Gears: whatever came stock. wanna posi tho
Just wondering how these would look. Don't want to shave the handles cause if the battery dies you're ****ed.
These would sit flush with the door skin. I believe like 87-90 GMC truck latter door handles.
Can anybody with Photoshop do this so I could see how they look?
Old Jun 22, 2013 | 07:10 AM
Engine: 3.1 v6
Re: gmc truck door handles
TTT
Old Jun 22, 2013 | 08:41 AM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
actually you can crawl through though the hatch.
Old Jun 22, 2013 | 11:03 AM
Engine: 3.1 v6
I'm 6'2" and 245 lbs. Plus I've had two neck surgeries...The hatch probably wouldn't be an option for me.lol
Old Jun 22, 2013 | 11:44 AM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
They look great & no Photoshop is needed. But the S10 handles are a bit smaller, if you wanted a smaller look.
This was mine back in the mid 90s after I got the idea from Hot Rod magazine that did it a few years earlier.
Old Jun 22, 2013 | 04:30 PM
Engine: 3.1 v6
That looks pretty damn sweet! How hard was it to do?
Old Jun 22, 2013 | 07:24 PM
Car: GTA
The "hard" part about doing it is the welding of the new piece in then paint & body.
I cut the truck pieces out of a junkyard truck. Nice & big for plenty of material to work with. Fortunately the yard loaned me one of those hand held chop saws. Made cutting it out a piece of cake!
Trim the donor body piece down to size, line it up (the screws were temporary), make sure it is square to the door edge level & cut the car body to line up with the donor piece. Set it in place nice & flush then weld. Woulda been nice to be able to flange the car body but magnets also hold it flush to weld it in place. Or just pay a body shop to do it for you. Better to pay & have it done right than to screw it up & hafta start over.
The plastic clips from the handle to the latch rod inside are the same between the trucks & 3rd gens but you will hafta cut & shorten the rod. No big deal. Just get the handle welded in then cut the rod to length to line up with the plastic clip. It'll make sense once you look inside.
Body filler to final smooth it all out, paint & your done!
This thread has basically the same thing with the S10 handles but he did it the hard way by not grafting in the metal from around the handle.
https://www.thirdgen.org/forums/fabr...or-handle.html
Old Jun 23, 2013 | 06:43 AM
Engine: 3.1 v6
Awesome! Thanks!
Old Jun 23, 2013 | 06:46 PM
flash2042's Avatar
Car: 83 Z28
Engine: LG4
Doing this to mine as well. They both latch the same way so it shouldn't be an issue. The biggest problem I can see is getting the rods the match up exactly, but if you're talented enough to swap out the bracket itself, modifying the rods shouldn't be an issue.
Old Jun 23, 2013 | 07:02 PM
zenish's Avatar
Engine: 305 tbi
one alternative to welding the rod might be using a cable clamp to connect the two rods together?
Old Jun 23, 2013 | 07:31 PM
Car: GTA
The only issue with the rods is that the 3rd gen rod needed to be shortened then the bend put back in. So all I has to do was cut & bend the stock rod. No welding, no clamping.
Old Jun 24, 2013 | 08:36 AM
Engine: 3.1 v6
Thanks guys! Once I get the cash they're going in my ride.
tglennon11
Sep 23, 2015 05:30 PM
billybob6110
Sep 23, 2015 01:30 PM
Amillionoh7
Sep 11, 2015 11:36 AM
tsfso59
Exterior Parts Wanted
Sep 9, 2015 09:09 AM
NiG
Sep 7, 2015 11:25 PM
