New Gauges in a 91 RS
Old Oct 4, 2001 | 06:23 PM
91RS5.7TBI's Avatar
Ok, I was wondering if I could put the gauge cluster from like an 87 IROC-Z like my dad's and make it work in my car. I hate the stock gauges, and I would do almost anything to get somthing better.
Old Oct 4, 2001 | 10:31 PM
MrsLottaBallsCamaro's Avatar
Aren't those the circle guages?
Old Oct 5, 2001 | 12:13 AM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
Yeah, the 87's are circles, the 91's are semi circles.
Third Gen Project - Website now defunct because crosswinds sucks
1989 305 tbi Camaro RS Red/Red
Ram Air II Hood
Centerline Champ 500 Rims
Edelbrock Open Element
MacEwen White Faced Guages
Old Oct 5, 2001 | 01:03 AM
Mac's Avatar
Mac
Car: 91 RS
Engine: 350 H.O.
ewwwww I hate those ones, keep the ones you got
Old Oct 5, 2001 | 07:10 PM
I've gotta agree with Mac. Those circle guages look like crap. I like the guages in my 91, although I wouldn't mind getting white face guages. If you really hate just the colors and not the guages as a whole, look for some white face overlays or go to www.blackcatcustom.com They have neat (but expensive) custom guage inserts.
Old Oct 5, 2001 | 11:54 PM
un4givin89's Avatar
You guys suck. I hate the 91 and up half moon gauges. They look queer.
Old Oct 6, 2001 | 05:30 AM
Sleipnir's Avatar
...then replace them...
shouldnt be that hard.
Old Oct 6, 2001 | 11:08 PM
So I suck because I like the guages in my car? If you think they look so queer, change them out and put some new ones in.
Old Oct 6, 2001 | 11:21 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
I like the 91/92 gauges, except the light goes right through so my home made white faced gauges look like crap at night. I gotta figure out how to fix that..
1992 Camaro RS
5.0L TBI
Custom white-faced gauges
K&N Airfilter and ready to take on the world!
My 1992 RS
Down with bin Laden
Old Oct 7, 2001 | 01:02 AM
92fire-audio's Avatar
I had the same problem when I put my white face guages in.. What i ended up doing was wiring 2 9" Mini blacklights under the dashpad (its almost completely hidden, i've got a strip of electrical tape covering the beam so i'm not blinded..) They light up the gauges GREAT. They glow a neon blue/purple color.. I've gotten a TON of compliments on these..
Old Oct 7, 2001 | 09:30 PM
91RS5.7TBI's Avatar
Ok, I want the circle gauges because I want to get a big white tach and speedo, and the half circle things, well, I just don't like them. I guess they are ok, but there are no aftermarket half circle gauges. The blacklight idea seems cool. thanks for the advice. *** knows I need all the help I can get when it comes to interior work.
Old Oct 7, 2001 | 11:49 PM
Kandied91z's Avatar
half moon guages are queer; hmmm.... ok
what if i told you having a 5.7 TB was queer. shouldn't it be a 5.0 or did you do the swap; and if so why didn't you do a TP instead of a TB or were you just confused?
If you could do a swap like that then guages should be no problem.
Old Oct 9, 2001 | 12:52 AM
91RS5.7TBI's Avatar
no seriously, the hardest part of the whole swap was finding the ECM so I could get codes to get a custom chip burned. The interior is greek to me. I learned on a 72 cutlass, the rs is my first EFI car, and the 305 sucked. Does anyone know what cfm the tb unit flows at? But man, I just hope the thing starts.
Old Oct 9, 2001 | 01:43 AM
Mac's Avatar
Mac
Car: 91 RS
Engine: 350 H.O.
I was not aware that guages had a sexual preference
1991 teal camaro RS rebuilt 96 350 marine motor, comp cam, accel ignition,8mm accel plugs and wires, hedman headers and y-pipe, and rear end with 4.10 gears. Stock 700r4, best 1/4 time 14.6
Old Oct 9, 2001 | 07:25 AM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
I'm pretty sure he didn't ask for anyone's opinion about the swap. He just wanted to know if it was possible. I'm sure it is, but will require a complete dash replacement and a lot of rewiring. You will have to adapt a security light and an air bag light to the older cluster. Get yourself a service manual for a 91 and an 87. You can look at the wiring diagrams and figure out what needs to be done. Good luck.
89 Transam GTA, 350TPI, auto, 3.27 rear, dual cats, gray.
Magnaflow cat-back,
K&N open element,
Best E.T. 14.63@95mph
Old Oct 9, 2001 | 09:26 AM
Car: '89 GTA
Engine: ZZ6TPI
The stock TB is 500cfm. Holley makes a 670cfm and Edelbrock makes a much better flowing manifold. Chip calibration will depend on your engine combo.
Magnaflow cat-back,
K&N open element,
Old Oct 9, 2001 | 01:43 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
personally, i LOVE my gueages compared to the older circle style. not sure how you can get them replaced though. i heard that they are different hookups or whatever.
-Brian
1991 Camaro RS - ultra blue metallic, t-tops
GMPP 350 HO crate engine - 454 TBI, MSD ignition, SLP exhaust, everything is new
700R4 - 2,400 stall converter, vette servo, shift kit
z28boy.cz28.com
Central New York F-Body Association
z28boy@twcny.rr.com AIM - "Z28 Boy"
Daily driver - <A HREF="http://members.fbody.com/z28boy/grandprix" TARGET=_blank>
1998 Pontiac Grand Prix GT</A> - 2 door, black
Old Oct 9, 2001 | 04:44 PM
91RS5.7TBI's Avatar
THANK YOU! That advice really helped. finally!!!
Old Oct 9, 2001 | 04:50 PM
Cornflakekid's Avatar
The gauges for the 82-90 Camaro have cable driven speedometers and late 90,91 and 92 are electrical. So you would have to buy a speedometer cable and do modifications through the dash.
If you kept the stock 82-90 cluster,
and bought an aftermarket electronic speedometer, to put in your Camaro you won't have to worry about a cable
(just alot of rewiring on your 91).
My two cents.
Old Oct 9, 2001 | 05:12 PM
Car: '89 GTA
Engine: ZZ6TPI
You'll need the entire dash from the 87', so the speedo cable should not be a problem. You'll have to mix the two wiring harnesses using the Service manuals as a guide. It's will no doubt be a lot of work and you should ask yourself if it's worth it before you start any work. Do as much research beforehand and make a wiring diagram to follow.
Magnaflow cat-back,
K&N open element,
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
Luigytico09
Oct 1, 2015 08:46 AM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
