digital gauge cluster question
Old Oct 8, 2001 | 10:14 PM
u r sofa king we tah did's Avatar
ive noticed the cyberdyne and intellitronix digital gauges, but on my 89 iroc with the cable driven speedo, it has the VSS mounted in the speedometer itself. i know the digital gauges require an adapter to convert to a signal that the digital speedometer can use, but does the replacement cluster itself send the computer a VSS signal so i dont get an error code?
Old Oct 9, 2001 | 01:53 AM
Jza's Avatar
Jza
The Cyberdyne dash has a VSS output wire that gives the computer a signal so it can work properly.
The Intellitronix dash requires you to take the VSS assembly apart from the mechanical speedometer itself, and keep it in the cluster, and it gives the computer the VSS signal (so you still need the speedometer cable to go all the way to the cluster housing).
[This message has been edited by Jza (edited October 08, 2001).]
Old Oct 9, 2001 | 02:31 PM
Trans Am's Avatar
Where can i find a picture of these digital gauges
thanks
Old Oct 9, 2001 | 09:11 PM
o2sk8's Avatar
Car: '87 IROC
Engine: Near Stock 350
Transmission: Stock 700R4
I believe these are what you are looking for:
Kodos: "To put you at ease, we have recreated the most common spawning locations of your species. You may choose either the back seat of a Camaro, an airplane bathroom, a friend's wedding, or the alley behind a porno theater."
Old Oct 14, 2001 | 03:12 PM
sinner's Avatar
Car: 1992 Camaro Z28
Engine: 1995 Camaro LT1
do they make these for a '92? where can i get them?
'92 Z28,t-top,PPG jet black,5.0L TPI,Auto w/stage 2 sft. kit,
michelin pilot 245/50/ZR16 tires,polished plenum/intake,flow tech 3" exhaust,PIAA driving lights,2 kicker 10" comp vr subs,jl audio componet set in q form kick panels,kicker ix405d 5 chanel amp,pioneer deh-p735 deck
Old Oct 15, 2001 | 01:11 AM
o2sk8's Avatar
Car: '87 IROC
I probably should have included this before, but they have the guages @ jegs.
<a href="http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=27607&prmenbr=76">GAUGE LINK</a>
Old Jan 14, 2002 | 04:23 PM
itailian 4 lyfe's Avatar
does any one have a picture of the Cyberdyne gauge inside the dash of a camaro??
Old Jan 15, 2002 | 11:23 PM
Coxy's Avatar
Car: 91 RS B4C
Engine: 355
Transmission: TH 350
I have the Cyberdyne set for sale complete in box f0r 84-90 camaro. E- mail mcox031398@msn.com
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
fonzie85
Aug 13, 2015 11:50 AM
ChevyZ71
Aug 13, 2015 07:30 AM
