man...im twisting this thing in half!!
Old Jan 9, 2002 | 01:56 AM
chevyboy07 91's Avatar
geesh, i finally got my hands on my dream car and its nicely modded. I'm now noticing the dreaded "torque cracks" up by the top of the passenger window(towards the back). it looks like my car is just twisting and tearing itself apart...like a pepsi can!! I know this is common for the t-top cars but damn man...this sucks. Now were the crack is...I SEE RUST FORMING!! I just had the whole car repainted and cant afford any paint work...what do I do to stop the rust at least for now? it's hard to see it b/c its small but it is there.....Time for some Spohn SFC's!
Old Jan 9, 2002 | 07:40 AM
scauffiel's Avatar
POR-15 and get SFC's ASAP.
Steve
Old Jan 9, 2002 | 01:05 PM
but i cant use the POR-15 on /along side my actual paint job....isn't it a different color? maybee ill just spot treat it w/ a very small brush and use touch up to cover it up?
Old Jan 9, 2002 | 03:09 PM
ryn28's Avatar
Car: 1986 Camaro Z-28
Engine: Chevy ZZ4
Transmission: Select Built 700R4
Axle/Gears: Moser Axles / 3.73 Richmond Gears
Nothing's going to look as good as the real paint but POR-15 makes a clear version. At least then it won't look or get any worse.
Old Jan 11, 2002 | 09:36 PM
89convertRS's Avatar
paint cracks
Man - get those fixed...If you got a base/clear car whey can sand the spots and feather the clear. If you dont the paint will continue to degrade in the area. Worse yet water gets under the paint and begins the oxidation of the steel AKA RUST.....
Like you said its your dream car...
Old Jan 13, 2002 | 03:00 PM
isercastik's Avatar
go to eastwood.com, they offer a pencil type thing that cleans the rust from the crack than touch it up with a brush 3-4 light coats and color sand it, itll look very presentable,
Jeremy
Old Jan 13, 2002 | 03:09 PM
Kandied91z's Avatar
are you sure those are torque cracks? most cars i've seen it was the factory paint that wasn't preped right in the common trouble area.......even newly painted cars sometimes get that right away.
Old Jan 13, 2002 | 04:55 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
T-Top cars have extra restraints from the factory but they are made to be good for a stock to mild car. People, if u are going to be crazy modding your car, get SFC's before u start.
Old Jan 13, 2002 | 08:43 PM
Kandied91z's Avatar
i agree, subframe connectors are a must.......
i was purly making the point, chevyboy07 91's car isn't making enough torque to twist the frame; that is if his sig is up to date.
sure these cars make torque alot of it, but sounds to me like more of a paint problem in itself then the car twisting in half........although, it can happen.
Old Jan 13, 2002 | 11:22 PM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
I have those cracks and I only have a stock TBI 305 with 140k miles on it. It's not rusting, but it has been repainted. So, it probly isn't from the twisting, because I doubt mine twisted with the measly power it can put out compared to some of you other guys cars.
Old Jan 15, 2002 | 09:16 PM
3gc's Avatar
3gc
Car: Z28
I have a 89' V6 RS and mine has them so it's not just power that does it. Mine was in an accident, that's most likely the cause for mine. I also have a few stress cracks in the cowl area.
Old Jan 15, 2002 | 11:37 PM
Administrator
Its not, sharp cornering, parking in certain places, hitting road imperfections, and launching in races and stuff all does it too.
Ghettobird52
Jul 5, 2024 11:18 PM
gta90
Sep 15, 2015 04:00 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
Bob88GTA
Aug 18, 2015 03:31 PM
