Should I keep my pin stripe and if not, how do I get ride of it
Old Oct 2, 2001 | 10:03 PM
PopaPork's Avatar
I guess my subject says it all. I have a 89 black RS and I just flipped the tires around to all black...sprayed my Side parkers black and well and debating if the gray pinstripe should come off. So i am looking for opotions. If any knows a good way to take it off...and not have it well look crappy, LET ME KNOW. Thanks
1989 RS Camaro
305ci TBI
Mods:
Hedman Header
Highflow Cat
3inch catback pipe
FlowMaster 80 Series Muffler
14x3 Open Air Element
8.5 HighTemp Spark Plug Wires
4.7 Ohm Reistor
Torque Converter Lock Up switch
www.rit.edu/~cjp8408
AIM: PopaPork
Old Oct 2, 2001 | 11:43 PM
85riceeater's Avatar
I would personally. Taking them off can suck though. To get mine off I used a razorblade. Its a hassle and take time, but would look great on your ride.
Old Oct 3, 2001 | 12:34 AM
87 Firebird's Avatar
Razor blades are severe bullship. Try an autobody supply store, and ask for "Pinstripe removal wheels" They're a rubbery wheel on a 1/4 inch shaft you put in an electric drill or other rotary tool and it rubs them off with ZERO damage to paint underneath. Fast and easy, just the little rubber bits make a mess.
Old Oct 3, 2001 | 07:52 AM
drtybrd's Avatar
All you have to do is take a hair dryer, heat them up and the stripes come right off.
Old Oct 12, 2001 | 07:34 PM
Some autobody supply places sell a thing called a "pinstripe removal wheel" It's basically a rubbery wheel on a 1/4 inch shaft that you put in an drill, die grinder, etc. Doesn't mess up paint, works beautifully.
Old Oct 13, 2001 | 12:18 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Buy some Quick 'n' Kleen and spray it on the pinstripe. As long as it is not painted on, it should disolve the adhesive enough that it will simply come off. Wipe up the residue with a rag and then cleen your car, should do it.
ALSO, GM has some decal remover stuff at the dealerships for removal of the decals. It should work too.
John
G O D BLESS AMERICA
87 Formula Yellow/Black
5.1 TPI Automatic
Baer 12" brakes 4 wheels, KYB AGX Adjustable Shocks & struts, Custom Leather interior, WAAAY TOO MANY MODS TO LIST
87 Formula TPI (5 Speed) Yellow/Gray STOCK
1967 Buick Riviera 430hp Turns high 14's (Not bad for 4300 lbs)
83 Camaro
83 T/A
http://www.3rdgenformula.com
Old Oct 25, 2001 | 03:33 AM
TBIfly's Avatar
Pinstripe Remover
just like those guys put it.....a wheel you place on a rotary and lightly press against the beginning of a stripe.
15 bucks i think i saw it for. looks sorta like those chunks of art erasers in 8th grade..but a wheel
Old Oct 25, 2001 | 05:48 AM
EvilCartman's Avatar
Car: '82 Z28
Another vote for the hair dryer!
'82 Z28
LG4 305 .030 over, performer intake, holley street avenger 670, xe 256 cam, tes headers, 3 inch single exhaust, spintech muffler, 14 x 3 inch drop base k&n.
Old Oct 25, 2001 | 12:54 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Personally, I would remove it. If I get the IROC I'm looking at, the first thing to go is the stripe along the bottom.
1992 Camaro RS For sale! Email me for info!
5.0L TBI
K&N Airfilter and ready to take on the world!
My 1992 RS
Rate my car!
Love the country or leave the country.
Old Oct 25, 2001 | 01:53 PM
BitchinCamaro's Avatar
My first car had a PINK stripe down the side... that HAD to go before I would even get in it. When I pulled it off it took sections of clear coat with it. I ended up having to put a grey stripe in its place. If you do take it off be careful, and take your time!
Old Oct 25, 2001 | 06:53 PM
WaynesRS's Avatar
Becarefull with a hair-dryer , you can mess up the paint . I messed up mine a little .Wayne
Old Oct 25, 2001 | 10:57 PM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
CARB CLEANER!
Disclaimer: DO NOT TAKE THIS ADVICE.
Old Oct 26, 2001 | 08:50 PM
MY 88IROC ROCKS's Avatar
<FONT SIZE=2 FACE="Tahoma"><font color="#000000"><font size=2>PopaPork: I just removed my pinstripes last weekend. Like some of the others, I used a "HOT" hairdryer (a cooler one didn't work that great...but watch your paint!) and also a bottle of Goof-Off to remove the sticky residue. I had no problems.
</font color="#000000"></font size=2>
</font>
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
z28venezuela
Oct 24, 2015 08:15 PM
Gordonr1973
Sep 29, 2015 11:59 AM
89bird2.8
Sep 25, 2015 09:21 AM
