Dimmer switch
Old Nov 21, 2001 | 05:45 PM
BlackBird91's Avatar
Dimmer switch
The dimmer switch isn't working, I cant even hear the usual click. Is there anything I can check or do without removiing the steering wheel.
91 firebird TA
5.7 TPI
WS6 package
Old Nov 21, 2001 | 06:55 PM
PhantomChamp's Avatar
The dimmer switch is such a pain in the arsh to deal with, that I still haven't replaced mine yet.
The actual switch is way down by the floorboard on the steering column. It looks hard to get to. Maybe someone will do a tech article on it.
Old Nov 23, 2001 | 08:35 AM
toosloz's Avatar
it is a pain....
i changed mine over and did it in about an hour....not hard....just a pain to get them screws inand the switch adjusted
Old Nov 23, 2001 | 11:22 AM
The switch isn't bad, its a piece in the turn signal thats broken, the actuator, dimer switch to rod,
The manual I have doesn't cover this. Can I replace it w/o removing the stearing wheel ?
The part is only $20.
[This message has been edited by BlackBird91 (edited November 23, 2001).]
Old Nov 23, 2001 | 06:13 PM
I really don't think there is a way to get to the stalk inside the column without removing the steering wheel. Do you have an airbag wheel?
[I did NOT edit this message, I got it right the first time.]
[This message has been edited by PhantomChamp (edited November 23, 2001).]
Old Nov 23, 2001 | 08:33 PM
I got the dealer to fax me a cut sheet on the steering columm the part thats broken is only $15.00 and goes right behind the turn switch lever and hooks to the rod. I still have no idea if it can be done without removing the steering wheel. Yes I have a air bag. the cheeeeep chiltons I have has no break down on this area of the car. has any one else had to replace this piece ???
Veaceonee
Sep 29, 2016 08:15 PM
RacerM
Sep 28, 2015 04:25 PM
327IROC85
Sep 23, 2015 12:11 AM
gta_knight
Sep 17, 2015 03:48 PM
Isaac McCormick
Sep 12, 2015 10:20 PM
