removing dried up old crap
Old Nov 30, 2001 | 12:52 PM
silentneko's Avatar
hey guys on my dash there is a strip of old dried up adhesive tape, the previos owner must have had a dancing hulla girl or something, how do I get this off without damaging or bleaching the dash.
neko
'87 trans am
car in the making
angelfire.com/fl2/neko
Old Nov 30, 2001 | 03:13 PM
Drew's Avatar
Try lighter fluid. Its fairly safe and will disolve adhesives.
Old Nov 30, 2001 | 05:30 PM
silentneko's Avatar
really, never would have guessed that, but will it leave a smell in my car.
neko
'87 trans am
car in the making
Old Nov 30, 2001 | 06:29 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
What about rubbing alchol?
Old Nov 30, 2001 | 10:34 PM
Belker's Avatar
I had a silimar problem and this is what I did - I pulled the dash from the car to make life easier, then got some "googone" and got off as much as I could, then picked at the grain with a sewing needle for at least an hour. It finally all came off but was a major hassle. Good luck. I hope yours is easier.
Old Dec 1, 2001 | 02:35 AM
Jza's Avatar
Jza
The lighter fluid will evaporate thoroughly enough not to leave a smell. If you're worried about spotting, test a small out of the way bit of dash first.
Rubbing alcohol is typically 20-30% water, so won't be strong enough to (or might not be) get the goop off completely.
[This message has been edited by Jza (edited December 01, 2001).]
Old Dec 1, 2001 | 12:48 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Lighter Fluid
Goo B Gone stuff
or Quick 'n' Kleen
John
G O D BLESS AMERICA
http://www.3rdgenformula.com
87 Formula 5.1 TPI Auto Modified (Yellow/Black)
87 Formula TPI (5 Speed) Yellow/Gray STOCK
14.8sec 1967 Buick Riviera
1990 Buick Riviera (driver)
83 Camaro
83 T/A
Old Dec 2, 2001 | 03:40 PM
Drew's Avatar
Rubbing alcohol has lotions and lubricants as well as a large amount of water. In past experiances I've seen it turn plastic white. Not exactly the reaction you want to encounter in the middle of a dashpad.
Old Dec 3, 2001 | 08:52 PM
bigvic's Avatar
Try this stuff called Ultra Citrus. Its sold in the automotive dept. at WalleyWorld as an air freshener. The citric acid in the stuff will take away the goo really fast and easy without damaging the dash. And in the end you will have a nice orange smell in your car.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
bamaboy0323
Sep 12, 2015 07:14 PM
Stroopwafel
Sep 11, 2015 06:38 AM
TheExaminer
Sep 6, 2015 11:40 PM
