a\c control swap
Old Nov 23, 2001 | 07:55 PM
whitemike92's Avatar
a\c control swap
does anyone know id it is possible to swap the a\c controls with one from another car.
i dont care much for the sliding controls in my 92' camaro.
Old Nov 26, 2001 | 02:08 PM
crumblinghevens's Avatar
I know how you feel, I'm willing to do a little work to get a mitsu 3000gt climate control system(the digital one) in my car. Nobody really responds to the questions, though. I suppose it would be a matter of splicing the wiring.
90 Firebird Formula "The car police love to hate!"
Old Nov 26, 2001 | 02:19 PM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
I would like to do something like this too. I'm afraid it will probably be a bit more involved than splicing wires. I bet you need to use the heaterbox and everything. Most AC compressors are pretty similar though, I think. Most that I have seen have 2 or 3 wires going to them.
Old Nov 26, 2001 | 02:58 PM
someone had told me that there are 2 kinds- cable and electric and he said i have a cable one. but that still doesnt help me....
Old Nov 26, 2001 | 03:55 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I have thought about this, and if you really want to know HOW to do it, find a car, any car with the climate control you want. Then look up in the service manual, there should be everything you need to know, where it is, how it plugs in etc.
I KNOW for a fact that my 90 Riv has either servos or little motors controlling the doors. So that will be something you have to install.
I never drive my car when it is too hot or too cold anyway so I have just left mine alone.
John
G O D BLESS AMERICA
http://www.3rdgenformula.com
87 Formula 5.1 TPI Auto Modified (Yellow/Black)
87 Formula TPI (5 Speed) Yellow/Gray STOCK
14.8sec 1967 Buick Riviera
1990 Buick Riviera (driver)
83 Camaro
83 T/A
Old Nov 26, 2001 | 07:48 PM
i really want to try to stay away from major modifications, so i would rather find a car wiht a similar set-up but better looking
Old Nov 30, 2001 | 07:04 PM
will a 4th gen one work?
Old Nov 30, 2001 | 08:01 PM
I don't think so. I believe(correct me if I am wrong)that third gen a/c is cable driven. I think fourth gen is more electronic. I've been checking this out, and it would make more sense to adapt the entire a/c system from whatever vehicle you'd like and retrofit it to our cars. That said, it's probably not cost effective, but sweet as hell. I really don't like my a/c controls. Anyone have any technical know-how for this?
Old Dec 4, 2001 | 09:59 AM
tommydodso's Avatar
YUP EVEN ON MY GTA IT HAS PUSH BUTTON AC BUT STILL HAS CABLE ON IT OPENS AND SHUTS VIA VACUUM. I HAVE LOOKED AT IT ALREADY. AS FAR AS SWITCHING IT LOOK TO SEE IF THE BACKS ARE THE SAME IF SO YOU MIGHT BE ABLE TO SPLICE IT IN GOOD LUCK.
TOMMY
Old Dec 4, 2001 | 11:44 AM
GndPrx's Avatar
The climate controlls in the thirdgen's are controlled by a combination of cable, vacuum and electric.
A cable controlls the temp setting
A series of vacuum tubes and gates control the redirect of the air and a/c vs. heat, etc...
A electric switch controlls fan speed.
I have looked at converting a 4th gen climate control and you would honestly need the entire heater core from the 4th gen to get it to work properly...I have yet to find a suitable alternative to what is already in our cars...although I would absolutely love to install a fully digital climate control setup.
Carl
CarAudio Resources
CarAudio Resources Forums are now ONLINE!
Old Dec 4, 2001 | 05:53 PM
here is what chiltons says on this issue:
The 1982-92 model vehicles covered in this manual use an R-12 refrigerant Air Conditioning (A/C) system. The Cycling Clutch Orifice Tube (CCOT) includes the compressor, condensor, evaporator, an accumulator/drier (with fixed orifice tube), and a clutch cycling switch (with or without a temperature probing capilliary tube to maintain a selected comfortable temperature within the vehicle, while preventing evaporator freeze-up). Full control of the system is maintained through the use of a selector control, mounted in the dash assembly. The selector control makes use of a vacuum supply and electrical switches to operate mode doors and the blower motor. A sight glass is not used in this system and one should not be installed. When charging this system, the correct quantity of refrigerant must be installed to obtain maximum system performance.
If anyone has some great ideas for rigging this up, now's the time. There's got to be some hot-rodding or ***** trick to this.
Old Dec 4, 2001 | 05:54 PM
I live in florida, so i dont really need heat in my car, can i swap the controls with one of another cars without the use of the heater
Old Dec 5, 2001 | 01:03 AM
probably not without swapping the entire system. It's not a matter of heat, it's a matter of how your a/c system controls the vents.
Old Dec 5, 2001 | 01:27 AM
loomdog32's Avatar
Car: 82 Camaro Z28
Engine: LU5 - Crossfire 305
Transmission: 200c - 3 Speed Automatic
i know the feeling. im tring to figure out how to swap the a/c controls from a 94 silverado z71 in my 83 maro. i was hoping that i would just have to take the controls out of my car and install the new ones. if i figure out anything ill let you guys know.
Old Dec 5, 2001 | 07:27 AM
GndPrx's Avatar
Well, 2 out of 3 of the controls would be very easy to swap...the cable driven temp selector and the electronic fan control would be a breeze.
Need to find someone who has a vacuum gate system that can be controlled remotely rather than having it directly attached to the slider itself.
Carl
[This message has been edited by GndPrx (edited December 05, 2001).]
Old Dec 19, 2001 | 12:13 AM
cp87GTA's Avatar
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Axle/Gears: 9" ford 5.67
Re: a\c control swap
You can use the set up from a third gen GTA. But you're looking at alot of work. You'll have to have the entire heater box with wiring and controls. I'm in the process of parting one out now.
eightsixseven
Dec 16, 2024 01:50 PM
midge54
Jan 29, 2017 07:00 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
nuggie
Aug 25, 2015 01:27 PM
