I don't like this gap!
Old Feb 28, 2014 | 04:39 PM
jazzdadss's Avatar
Car: 1989 IROC LSX
Engine: Swapped LS6 Forged by LME
Transmission: 4L65E
Can anyone tell me what causes this gap between the hood and front facia? And possibly how to fix it?
Old Feb 28, 2014 | 05:26 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: I don't like this gap!
What do the edges look like?
Are they lined up properly?
That would tell us if it’s the hood that's high or just the bumper cover that is sagging.
Mine was the hood that was high and I ground away material on the latch bolt holes to allow the latch itself to slide down further and removed as much gap as I could
.Before =
After =
Old Feb 28, 2014 | 05:48 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
theres a plastic bar behind there that you can slightly adjust. its hard to get to IIRC? maybe somebody can descibe how to adjust it better? this hawks diagram might give you an idea?
http://www.hawksthirdgenparts.com/pr...l%2C-Used.html
personally, i play around with washers as spacers under the bumpercover til it meets up good.
Old Feb 28, 2014 | 07:29 PM
TheExaminer's Avatar
Car: 92 Formula WS6, T-top
Engine: 5.7L T.P.I.
Axle/Gears: Limited slip, 3.23 10 bolt
Lining up the front bumper, hood and headlight doors on a Firebird can also be annoying. I dont know what happens to 'em, but they move over the years.
Old Feb 28, 2014 | 09:33 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
.Before =
After =
Thats how I would do it
Old Mar 1, 2014 | 10:34 AM
jazzdadss's Avatar
Car: 1989 IROC LSX
Transmission: 4L65E
Well, I lowered the hood latch as low as it would go. That closed the gap pretty good and it still opens and closes nicely. Now the problem is that the facia is under the hood ( like a bad overbite). The hood edges are lined up nice to the facia and even gaps around the hood. I am afraid I wont be able to move the hood back any for fear of contacting the wipers.
Old Mar 1, 2014 | 05:30 PM
Engine: LQ4 ls 6.0
How well does you hood line up with the fenders at the rear
Old Mar 3, 2014 | 09:12 AM
jazzdadss's Avatar
Car: 1989 IROC LSX
Transmission: 4L65E
pretty good. I will take more pics when the arctic air goes away........
Old Mar 3, 2014 | 09:33 AM
jrhaus76's Avatar
Car: 1989 IROC-Z28
Engine: L98 - 350 TPI
Transmission: MD8 - 700R4
Axle/Gears: GH3/G80 - 2.77 POSI
Ah, the joys of panel alignment.
Old Mar 3, 2014 | 10:00 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
If it's flush with the fenders(lines all line up) then the nose needs adjusting.
Old Mar 3, 2014 | 11:14 AM
hrspwr's Avatar
Car: 86 IROC
Engine: 350 Vortec TPI
Axle/Gears: BW 3.27
Remove the TPI snorkel.
Remove the air filter holder.
There will be a bracket that bolts to the top and bottom rad cradle that holds the hood latch. If you look just below the latch, there will be another bracket that goes from this one to the front clip. The two bolts where the two brackets meet are slotted and you can move the front clip up.
If that is not enough adjustment, then you can shim the front clip and the plastic reinforcement piece that it sits on. That will also close the gap.
I would first line up the hood to the fenders and then move adjust this.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
diana227vegas
Jul 8, 2016 12:27 AM
Dialed_In
Aug 20, 2015 01:45 PM
TheJoeY88
Aug 13, 2015 06:51 PM
