How do fill my antenna hole in front fender
Old Mar 10, 2015 | 12:31 AM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Ive always welded up the hole in the pass fender for the antenna hole and then used filler and such to cover it up. I'm not sure I want to do that on some cheap cheap repro fenders I ordered. Looking for something different to do with it to cover it up but not permanently. I don't have a radio and prob never will but I don't know if I want to go through all that trouble again lol.
Old Mar 10, 2015 | 02:47 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: How do fill my antenna hole in front fender
I will probably get killed for saying this but it will work.
Clean and rough up the bottom of the hole with sand paper then tape over the bottom of the hole leaving a small cup.
Just enough to hold some JB Weld.
Mix it and put enough in the hole to extend beyond the top layer of the fender metal.
Let it cure overnight then sand it flush. Its so strong you will have to drill it out to remove it.
It is paintable.
Those that laugh should read this =
http://www.jbweld.com/product/j-b-weld/
Old Mar 10, 2015 | 07:38 AM
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
Put a black plastic grommet in it, ever want to put an antenna in, you can pop it out.
Old Mar 10, 2015 | 08:29 AM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
http://www.clipsandfasteners.com/Pla...as1379-100.htm
Old Mar 10, 2015 | 11:00 AM
Nonwoven29's Avatar
Car: 1986 Iroc z28
Engine: 5.0
I can see both points here. There 2 completely diffrent approaches. The plastic plug might look more Oem and is easily pulled.
The bondo putty jb weld etc. if done right will look flush smoth not factory but higher class show like. Like a shaved door handle.
Not even the same thing no apples to apples here.
Old Mar 10, 2015 | 01:04 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Some replacement fenders don't come with the hole, you have to drill it.My GM fender is like this.
What's that 3M sheet metal with the adhesive backing called? A member used to "flush" his door handles, mount it from the back though & finish it as desired up top.
Old Mar 10, 2015 | 04:18 PM
PurelyPMD's Avatar
Engine: LB9
Which brings up the next logical question. What do you do if you don't have a hole? Drill it, go with a power unit in the quarter? Glass mount on the hatch? My 87 has a pair of NOS fenders on it with no hole.
Attached Thumbnails How do fill my antenna hole in front fender-img_5486-1280x960-.jpg
Old Mar 10, 2015 | 04:46 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Looks so much better without the antenna hole. I've heard about the glass mount type of antennas with some good and bad reviews. Depends on the quality of the part?
Old Mar 10, 2015 | 05:19 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Depends on how radio you listen to.Mine stock ant is mounted under the headliner, just above the windshield, works pretty good, but I listed to mp3/cd 99% of the time.
Does look cleaner though, which is why I did mine.
Old Mar 10, 2015 | 09:54 PM
Engine: TBI,5.0
I bought a few plugs for the pipes that are still there left over with the A/C removal and they are surprisingly flat. The JB is going to be more of an eye sore until its painted. As mentioned above I would find a plug in one of those pull out drawers at your local Hard wear store and try that first.
Old Mar 11, 2015 | 12:50 AM
Joe Tag's Avatar
I hated the two foot mast the car came with. I got a 6" shorty (cue the jokes now) same style and it's practically invisible.
Old Mar 11, 2015 | 12:52 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Got one of those on my S10, also clean looking.
Old Mar 11, 2015 | 07:13 AM
PurelyPMD's Avatar
Engine: LB9
Good tip - headliner is out for replacement anyways. Did you insulate it from the body in any way or just stick it up there above the the visor area?
Old Mar 11, 2015 | 07:38 AM
Joe Tag's Avatar
The base needs to be grounded but the mast is insulated from the body. If you go that route I would just pony up for a hidden antenna. Do a search, they're all over the web under $30.
Old Mar 11, 2015 | 07:45 AM
PurelyPMD's Avatar
Engine: LB9
I like that even better - thanks Joe!
Old Mar 11, 2015 | 11:13 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
It's just tucked up right at the edge of the headliner/windshield.
Those hidden (loaded) antennas don't have as good reception as the stock unit.
I still love the old school antennas that were IN the windshield, (sandwiched between the two layers).
Old Mar 11, 2015 | 01:20 PM
Engine: TBI,5.0
Its to bad you could not use the defogger grid in the rear windshield.
Or could you ?
Old Mar 11, 2015 | 05:39 PM
Night rider327's Avatar
Car: 1988 Camaro
I shaved mine by welding, grinding, sanding, filling.. Then mounted the stock antenna up under the dash. Works pretty good.
Ron's idea is a great one if you don't want to weld the hole up. I have used JB weld epoxy to fill in many holes on car bodies through out the years.
I would always use a ball peen hammer to dimple the hole in some, rough it up with 36 grit paper, back taped the hole and fill with JB weld.
Old Mar 11, 2015 | 10:29 PM
Car: 87 TA clone
Thanks guys… unfortunately my CR brand tawian made fenders came with the antenna hole punched already. Ive done the whole weld and putty with great results but wasn't sure if I wanted to do that with these… just in case I decide to throw a radio back in. But I would never listen to "radio" more like MP3. I however do not have any of the hardware to mount any antenna to the fender… like the threaded shaft and the top nut.
I need this top nut
http://www.ebay.com/itm/321289586952?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
and this tube right?
http://www.ebay.com/itm/8292-Camaro-...-/331451835293
The cup plug might work… but it won't look that great. Im a firm believer of patching it right, although JB weld is great stuff and Ive used it a lot I wouldn't hear… not esp if something happens like lean on the fender and it cracks/loses the bond and the paint gets alittle weird… that would drive me nuts.
FWIW Ive had the hidden antennas that tape to the perimeter of the windshield and while they work they don't work that well.
Old Mar 11, 2015 | 10:32 PM
mantaguy's Avatar
Engine: 5.0 EFI
I might have those parts.let me know.
Old Mar 11, 2015 | 10:38 PM
Joe Tag's Avatar
Those two parts you showed do not go together. One is for power, one is not.
This goes with the nut for a non power.
http://www.ebay.com/itm/Camaro-Firebird-Manual-Antenna-Bezel-New-GM-/291402268610?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1986%7CModel%3ACamaro&hash=item43d8edbfc2&vxp=mtr
Old Mar 11, 2015 | 11:02 PM
Car: 87 TA clone
http://www.ebay.com/itm/Camaro-Fireb...edbfc2&vxp=mtr
How does that mount to the firebird fender? It has a cutout for 2 tabs on the hole and I see the tabs on the mount you posted a link to. So it fits down and then rotates and locks in place?
Car: 87 TA clone
Im def not looking for the power antenna version. If you got the fixed mount stuff… send me a PM of how much.
Old Mar 11, 2015 | 11:07 PM
Joe Tag's Avatar
Do you have the part with the cable and the brace for under the fender with the bolt coming out? The bezel fits over it and is indexed by the notches. The nut tightens it all down, then the antenna screws on top of it all.
Old Mar 11, 2015 | 11:47 PM
mantaguy's Avatar
Engine: 5.0 EFI
I only have these.
Old Mar 14, 2015 | 09:23 PM
MY87LT's Avatar
Car: 1987 Camaro LT
We had to Novas, a 1977 and 1978 and they had that windshield antenna. They worked fine.
Old Mar 14, 2015 | 09:25 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Or could you ?
I was on a Corvette site and some guy used his defogger grid for an antenna. But had to give up the use of the defogger.
Old Mar 14, 2015 | 09:55 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Wish they still made them.
Old Mar 14, 2015 | 10:35 PM
peterc005's Avatar
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
I removed the fender antenna before the paint job, and replaced it with a powered internal antenna.
Made a small steel plate and welded it under the antenna hole and then covered used filler (bondo?) in the hole.
Old Mar 15, 2015 | 08:21 PM
Car: 87 TA clone
Nope, literally just have the fender with a hole in it. THe OEM power antenna is long gone and still has the small L bracket on the inside of the fender to mount the power antenna. BUt thats about it.
Old Mar 15, 2015 | 08:22 PM
Car: 87 TA clone
I only have these.
how does the threaded top piece fit onto the fender mount? Im sure there is more that I would still need for that to bolt up.
Old Mar 15, 2015 | 08:29 PM
mantaguy's Avatar
Engine: 5.0 EFI
The angled piece goes on 1st(that's for the fender) then the threaded part get screwed to the antenna mast,then the antenna(same threading)
Old Mar 15, 2015 | 09:10 PM
Joe Tag's Avatar
If all you're wanting to do is fill the hole for now and leave the possibility of putting a functional antenna in, you can find a bolt of the same diameter and thread to fit the antenna. One of the metric body bolts fit it, I checked my old one. Make some sort of brace with the same angle as the fender for the underside to keep it vertical. Then use the two pieces manta pictured and a shorty or regular antenna. Otherwise, it cost me about 50 for everything when I got mine. You may want to check with one of our vendors.
pic of what's missing
Old Apr 19, 2024 | 01:58 PM
russ89gta's Avatar
Car: 1989 pontiac trans am gta
Engine: tpi 5.7
Transmission: th700r4
Thanks mantaguy for the clips and faster link. I’m happy with the look for now.
My power antenna stopped working around 2003 and I’ve always hated it sticking up. I removed the radio last year and made a delete plate. So removing the antenna just made sense.
Old Apr 19, 2024 | 04:20 PM
knightfire's Avatar
Car: 1984 Trans Am
Transmission: Manual
It would take longer to read through this thread than to weld a small patch in.
Old Apr 19, 2024 | 06:04 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
9 years later though.
Old Apr 20, 2024 | 01:33 AM
knightfire's Avatar
Car: 1984 Trans Am
Doh!
Old Apr 20, 2024 | 08:40 PM
mantaguy's Avatar
Engine: 5.0 EFI
Your Welcome,Anytime,Better Late than Never
'87IROCZOWNER69
Apr 4, 2011 11:28 AM
Stu's '85 IROC
Nov 8, 2007 07:49 PM
hbranontn
Exterior Parts Wanted
Jul 29, 2006 01:07 AM
logikal6785
Jun 21, 2002 08:35 AM
89formula#1
Car Audio
May 7, 2002 08:37 PM
