wheel well, black paint or undercoating?
Old May 24, 2015 | 10:23 PM
SOCAL-Z's Avatar
Car: 87' IROC
What should I use for the wheel wells black paint or undercoating?
Old May 25, 2015 | 03:12 AM
ronchic's Avatar
Car: 1986 firebird
Engine: 305 v8
Transmission: auto
Axle/Gears: 2.73 ?
Re: wheel well, black paint or undercoating?
i would use black satin paint ?
Old May 25, 2015 | 08:25 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Factory was body color and some undercoating.
Old May 25, 2015 | 01:33 PM
zero13's Avatar
Car: 91 Z28
Engine: Enhanced 5.0L
Axle/Gears: 3:42 Posi
Daily driver/durability= undercoating
show car/weekend ride= paint..to match car..or black satin.
Or..if you can get car on lift for a day, wire brush as much as possible, mask certain parts off..and undercoat..can use the aerosol cans from 3m ...helps with looks,sound,durability,and cleanliness.
Old May 31, 2015 | 06:29 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I say Undercoat but ger an Undercoat that tries fairly hard so you can scrub it. The flexible stuff is not easy to clean. Paint would chip to easily. Epoxy paint might hold up for the longest between respray.
Old Jun 1, 2015 | 01:18 PM
Metalizer's Avatar
I'm in the same boat, I need to get the bottom side painted so I can start installing parts back on. Under coating seems to be the best option for durability.
What's the best stuff to use?
Old Jun 1, 2015 | 02:37 PM
z28yourstang's Avatar
Car: 1986 z28
Engine: 350 hsr
Transmission: probuilt 700r4/edge 2800
Axle/Gears: stock 4th gen 3.23
Get rubberized undercoating from dupli color I think. It comes out darker then most undercoatings which come out kinda grayish.
Old Jun 2, 2015 | 04:14 PM
roadthrills's Avatar
Car: 1982 MSE, 1988 S10 Blazer
Engine: 305 in both!
Transmission: 200c / Th700r4
Axle/Gears: 3:73 / 3.42
My local body supply has several different shades and textures of undercoat. I went with the smooth finish satin black on our show truck.
Old Jun 2, 2015 | 10:59 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Here's what was on the car from the factory.
Old Jun 4, 2015 | 07:27 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Keep in mind that Scott's car is a Van Nuys car, Norwood might be different. My 87 Norwood car had a lot more undercoating on it than that, and my car was yellow...
Old Jun 4, 2015 | 09:02 AM
scottmoyer's Avatar
Here's a front wheel opening.
Old Jun 4, 2015 | 09:08 AM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Oooooo, shiny.
Old Jun 5, 2015 | 06:42 AM
DaveBerlinetta's Avatar
Car: 1985 Berlinetta
Engine: 5.0 LG4
Axle/Gears: 3.08 Peg Leg
Scott, thanks for the pics!
Old Jun 5, 2015 | 07:47 AM
okfoz's Avatar
I see Scott got out the Strut polish... That car is unbelievably clean.
Old Jun 5, 2015 | 07:57 AM
scottmoyer's Avatar
I still have more to go since the car had the beeswax undercoating (Rusty Jones) applied when new. One issue I have now is that the parts that have been protected for 20+ years looked fantastic when first cleaned, but now have light surface rust on the unpainted undercarriage components. Last week I saw some pics of a low mile 91/92 that had been taken care of by the previous owner with WD40. The undercarriage looked like new with no rust at all. I don't think I'll be getting under the car any time soon for that much detail.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
kah992
Aug 19, 2015 02:55 PM
