How to find Polyurethane welding rods on ebay?
Old Sep 16, 2015 | 10:42 PM
evilstuie's Avatar
Car: 1985 Pontiac TransAM
Engine: 400SBC 24x conversion
Transmission: T700r Stage2 Shiftkitted
Axle/Gears: 2.77 9 Bolt
Hi Guys,
Just trying to find some Polyurethane welding rods to do a mod/repair on my bumper but can't find any anywhere.
I've tried searching R01, PU, PUR, polyurethane rods, nothing seems to come up.
I'm in Australia and need a place locally or with cheap overseas shipping, and only need a few to get the job done.
Any ideas?
Old Sep 17, 2015 | 05:36 PM
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
Re: How to find Polyurethane welding rods on ebay?
If it's a cosmetic repair, I've had good luck with this:
But it's not for structural repairs.
Old Sep 17, 2015 | 05:48 PM
evilstuie's Avatar
Hey,
No unfortunately its welding a large piece in the top centre of the bumper.
I tried fibreglassing to repair but I'm now afraid that it will crack because of the different thermal properties between the resin and the PUR bumper material.
At the very least the paint will probably crack when it heats and cools.
https://www.thirdgen.org/forums/showthread.php?t=720553&goto=newpost
I still have the original piece I cut out of the bumper, so I was thinking I can probably just weld that back in at the angle I wanted and sand it back to get the shape I want, but now I need the PUR / R01 rods to do it.
Old Sep 17, 2015 | 09:28 PM
96BlownSSragtop's Avatar
Car: 89 Formula
Engine: Nada - v4.0
Transmission: Nada - v3.0
Axle/Gears: Nada - v3.0
Amazon.com: 3M 08101 Structural Adhesive Tube - 2 fl. oz.: Automotive Amazon.com: 3M 08101 Structural Adhesive Tube - 2 fl. oz.: Automotive
Schit works awesome. I've always used a flat piece of the bumper cover,ground effect, whatever, behind the repair and bridging both sides along with this. I can't remember how many time I've used this product and never been disappointed or had a failure. Just make sure you REALLY rough up the surfaces between the adhesive prior to clamping everything together.
Repaired the front bumper cover on the car in my sig pic in 1997 and it's still holding and looking great!! The link is through Amazon and takes you to Walmart but you can get it anywhere.
Old Sep 20, 2015 | 02:40 PM
evilstuie's Avatar
Thanks for that, it seems to be as difficult to find as the PUR rods, but at least it's showing up on ebay. Now I just need to find a flat piece of PUR bumper I can use to put in place of the fibreglassed piece.
Old Sep 20, 2015 | 06:48 PM
Yenipenny's Avatar
Car: 92 RS Heritage
On Ebay search for plastic welding rods. I've just checked and they show any kind you could want; however, The 3M product shown above for flexible repairs is ideal if used as directed...much better than plastic welding. Just to be sure, this is what I'm talking about:
http://www.ebay.com/itm/3-M-05895-Rubber-Plastic-Bumper-Cover-Flexible-Parts-Repair-Kit-5oz-Tube-Kit-/281645654774?hash=item419363a2f6&item=281645654774&vxp=mtr
I've used it many times professionally and on my own cars.
Old Sep 20, 2015 | 07:07 PM
evilstuie's Avatar
3 M 05895 Rubber Plastic Bumper Cover Flexible Parts Repair Kit 5oz Tube Kit | eBay
Yes, and as I said, ebay comes up with all types, except the PUR/PU polyurethane rods which I need, and the other catch is they have to be able to ship to Australia for a reasonable price.
Also this isn't for a repair, its to remove the nose tip on the 85 bumper to allow the K.I.T.T scanner light to fit with the stock bumper, so I have to put a 24" x 3" piece of polyurethane in the gap and then blend/melt/glue/weld it into the stock bumper.
If you check out the link I posted originally, it will show what I'm doing (trying to do anyway) to get a better picture of what I'm chasing.
Old Sep 23, 2015 | 08:23 PM
Car: 89 Formula
Engine: Nada - v4.0
https://www.hejetproducts.com/
http://www.eastwood.com/tpo-teo-and-...-80w-iron.html
Old Sep 23, 2015 | 08:29 PM
evilstuie's Avatar
hetjet was good @ 30 x 12" PUR rods for $17.95
and then only $148 to ship them to Australia......
Eastwood link is for PP,TEO and TPO, not PUR
Old Sep 23, 2015 | 08:44 PM
evilstuie's Avatar
I just found a supplier in Australia:
Techspan:
3mm x 25meter (smallest available) for $53.55 +$19shipping
So we'll see how we go.
Thanks everyone for the links and info.
Old Sep 24, 2015 | 12:04 AM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
They have change part # but if you will look up urethane supply company in alabama they have anything you need for plastic welding
Frozer!!!
Jan 19, 2024 04:55 PM
Reborn756
Sep 4, 2015 03:42 AM
yankeecarman
Convertibles
Aug 23, 2015 07:47 AM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
