Strut Tower Rust Hole
Old Jan 6, 2016 | 09:01 PM
Streetstuff's Avatar
Car: 1985 Camaro
Engine: 5.3
Transmission: 4L80e
Axle/Gears: 3.42 10 bolt
I got a problem here. Can you even buy replacement strut towers?
Old Jan 6, 2016 | 09:06 PM
B4C5.7's Avatar
Car: 1989 IROC G92 LB9 MK6
Engine: LB9
Transmission: MK6
Axle/Gears: 3.45
Re: Strut Tower Rust Hole
No repop yet to my knowledge, you just need some clean TN salvage.
Old Jan 6, 2016 | 09:13 PM
Car: 1985 Camaro
Engine: 5.3
Transmission: 4L80e
It was pretty rusty underneath so I did a little poking around... and then my dad shoved some pliers right through it.
Old Jan 6, 2016 | 10:44 PM
DonW's Avatar
Car: 1983 Z28
Engine: Carbed 305
Not cool. Can you zoom out just a bit? How big is the rotted area?
Old Jan 6, 2016 | 10:52 PM
Car: 1985 Camaro
Engine: 5.3
Transmission: 4L80e
As you wish. Thats before it got punched out btw.
Old Jan 7, 2016 | 06:29 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
that top piece is just spot welded on IIRC. You should be able to cut one out of a donor car and replace it. If the rust goes beyond that top piece, it will get a lot more involved. I wouldn't say it is an easy fix, but nothing that cant be done. I have the same issue on one of my towers on my dirt car.
There have been members on here that have replaced the cap. Just look around some. One guy had some good pictures.
Old Jan 7, 2016 | 06:09 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
This is what I am currently doing, taken out of a 92 Camaro to repair and transplant to my 89 IROC-Z.
This cap is finished, rust hole fixed by cutting out the rust and welding in a new section of metal.
This wheel house is almost finished, need to smooth it out some and weld the cap back on.
The other side waiting to get started.
This is what the rust hole looked like on the other cap that I completed.
Old Jan 11, 2016 | 10:02 AM
Car: 1985 Camaro
Engine: 5.3
Transmission: 4L80e
Thanks for the pics AaronIROCZ, whatever I end up doing I'll try to get some pics on here.
Old Jan 16, 2016 | 09:14 PM
monkey-leader's Avatar
Engine: 6.0L LY6 (Vortech Supercharged)
Transmission: Tick Performance T-56
Perfect time for a tube front end...
Old Apr 16, 2021 | 03:12 PM
Helper's Avatar
I have rust in the same area. Is the metal doubled on the flat part of the cap? As in does both the wheel housing and the cap need to be repaired? Or does the wheel housing have a big opening above the strut and the strut bolts directly to the cap (strut bolts do not also go through the wheel housing?)
As you wish. Thats before it got punched out btw.[/QUOTE]
Old Apr 17, 2021 | 08:02 AM
Helper's Avatar
Attachment 322238
Attachment 322239
Attachment 322240
Attachment 322241
Attachment 322242
I can almost tell from your pictures, but was wondering does the wheel housing metal end just above where the spot welds are, or does it extend to under the flat strut mounting surface of the cap?
Old Apr 19, 2021 | 08:29 AM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
The sheet metal is double layered where the strut mount holes are located.
klein
Jan 4, 2016 12:24 PM
Onbusy
Jan 3, 2016 02:52 PM
albundyz
Southern California Area
Jan 2, 2016 10:14 AM
racerx520
Dec 21, 2015 10:02 AM
