How do I remove 1992 camaro RS emblems
Old Jun 1, 2016 | 02:44 PM
santiclause's Avatar
Car: 1992 Camaro RS T-Tops
Engine: 305 V8 5.0L
Transmission: 4LE60 Automatic
Hey, I was wanting to replace my 1992 camaro RS emblems on the 2 sides and the one on the back, but how do I remove the ones that are already on the car. I'm not sure if they are on there with double sided tape, or held on with speed nuts or what..I've been reading different things.
Thanks.
Old Jun 1, 2016 | 02:55 PM
Queball's Avatar
Car: 92 Camaro RS
Engine: 5.0
Transmission: 700r
Re: How do I remove 1992 camaro RS emblems
on the side skirts/gfx its just a sticker sort of thing made of plastic about 1/8th thick
just pry it off with flat screw driver.
Old Jun 1, 2016 | 08:13 PM
zero13's Avatar
Car: 91 Z28
Engine: Enhanced 5.0L
Axle/Gears: 3:42 Posi
i thought there were mounting tabs in the back..but here's a way to test that...and remove at same time..."floss" 'em off with a guitar string/metal wire....get wire behind one side and floss 'em up and down while working to the opposite side..If you hit a tab, then you know there's tabs....if not continue to other side...then get heat gun/hairdryer to get goo off..remember to move gun frequently as to not bake your paint...
Old Jun 1, 2016 | 09:31 PM
Engine: 305 V8 5.0L
sounds like a good idea zero, I'll do that. Here's a question, Hawk's says this is for an 87-90 camaro....why not a 92 camaro? Whats the difference.
http://www.hawksmotorsports.com/87-9...lete-set-of-3/
Old Jun 1, 2016 | 11:58 PM
mk1431's Avatar
Car: 89GTA Black, Black cloth
Engine: LB9 26,000 miles
Axle/Gears: 3.45 Australian 9 bolt
dont use metal to floss off emblems use the white plastic straps they use to strap cardboard boxes closed when you recieve packages take the straps and split into 1/8 inch strips
Old Jun 2, 2016 | 09:46 AM
Engine: 305 V8 5.0L
Got the rocker panel and back bumper emblems off, now what about the hood emblem how is that attached?
Old Jun 11, 2016 | 09:36 PM
zero13's Avatar
Car: 91 Z28
couple of 10mm speed nuts i think..can reach yer hand in there with a socket....did your rocker emblems have tabs?..Let everyone know..or post a pic...help another member out...
Old Sep 28, 2017 | 08:13 AM
MelodyS's Avatar
@santiclause (or anyone that has completed this task)
How do you even start the process since it is recessed in the panel?
Any tips would be most appreciated. 1992 25th Anniv / Heritage
Attached Thumbnails How do I remove 1992 camaro RS emblems-20170721_181751.jpg   How do I remove 1992 camaro RS emblems-screenshot_20170928-090551.png   How do I remove 1992 camaro RS emblems-20160618_165002.jpg
SpectroRacing
31
Sep 18, 2020 12:30 AM
MelodyS
Camaros Wanted
Jun 20, 2016 02:45 PM
Rule69
Camaros Wanted
Mar 23, 2016 10:07 PM
I_R_GRUNT
Mar 20, 2016 11:03 AM
87cam305
Mar 17, 2016 11:27 AM
