Headlight Motor Spinning but not grabbing
Old May 10, 2018 | 08:44 PM
JB89TA's Avatar
Bave an 89 trans am... Having some trouble with the headlight motor. When I flip the switch the headlights sometimes pop up and sometimes they don’t. Sometimes it will get stuck half way. It’s only one of them by the way. I noticed that the top of the motor is spinning very fast and keep spinning long after the working one stops. To me it almost seems like something in the motor isn’t grabbing whatever mechanism nonnects to the headlight to make it go up and down. Any idea what’s causing this and how I can fix it?
Old May 10, 2018 | 08:46 PM
JB89TA's Avatar
Re: Headlight Motor Spinning but not grabbing
Wow... didn’t realize how many spelling issues i had until posted it.
Old May 10, 2018 | 09:12 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
There are 3 little plastic pucks which drive the gears in the motor. They break and turn to dust and everything spins. TDS makes some nice repair kits to solve that problem.
Old May 11, 2018 | 06:54 AM
JB89TA's Avatar
What’s TDS? Do you have a link?
Old May 11, 2018 | 07:19 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Top Down solutions. The owner Lon is a sponcer here
Old May 11, 2018 | 10:39 AM
Davidgou's Avatar
Car: '88 Black GTA, T-tops, digital dash
Engine: 5.7 TPI w/custom chip
Axle/Gears: 9 bolt 327 posi
Those kits work great. I repaired mine years ago with TDS kits and I also rebuilt the hatch pull down motor with their kit and they still work fine.
Old May 11, 2018 | 11:17 AM
JB89TA's Avatar
Excellent, thanks for the help. I have seen other threads talking about the plastic gear in the motor. If I am going to be taking it apart does it make sense to just change that gear with a brass one at the same time?
Old May 11, 2018 | 12:28 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
http://www.top-downsolutions.com/hea...ght-repair-kit
Old May 12, 2018 | 12:11 PM
82tarecaro's Avatar
Your gears should be fine. Those 3 plastic pieces turn to dust and they are what is locking the gear to the output shaft.
Old May 12, 2018 | 03:32 PM
JB89TA's Avatar
Thanks! I’m going to order the kit and see how it goes.
Old Jun 11, 2018 | 06:45 PM
JB89TA's Avatar
Just a follow up in case anyone else ever refers to this post for the same issue. I am far from a mechanic and with the kit from TDS (and a little youtube help
) I was able to do the entire repair in about 30-45 minutes.
Old Jun 11, 2018 | 10:17 PM
Drew's Avatar
Not a bad video, but I'd say it's easier to go under the car, and remove the lower bolts between the lower bracket and the radiator support. Reason being that there's less adjustment between the bracket and the body, than between the headlight bucket and the bracket. Makes it easier to realign when it goes back together.
Old Jun 12, 2018 | 09:52 AM
DynoDave43's Avatar
Glad you got it going.
Dark91z28
Brakes
Jun 1, 2010 12:41 PM
91_GTA305
Brakes
Aug 22, 2009 10:29 AM
89mulletbird
Feb 22, 2004 12:20 AM
Rippin92RS
Oct 16, 2003 08:50 PM
RegaPlanet
Mar 4, 2003 02:57 AM
