Bad Wiper Motor?
Old Nov 15, 2018 | 04:35 PM
DoctorStoopid's Avatar
Car: 1987 Trans Am
Engine: LG4 305
Bad Wiper Motor?
Hi everyone,
I've done a search and believe that I know what my problem is, but I didn't want to resurrect a dead thread just to confirm that I think that I know what I'm talking about.
I'm sure lots of us have had this problem, but basically, my 1987 intermittent wipers don't move at all unless I turn them to high speed, and even then, they only move up and down an inch or so. No other movement on any other setting.
In other threads, some people say it's the contact points, others say its the motor itself, and a few say it's the electrical pigtail connector. My black circuit board looks brand new and all the contact points have been cleaned and look good. This makes me think it's the motor itself that needs replacing.
I've included a link to the video. If someone could tell me if this is indeed the problem, I would really appreciate it. With the black cover on OR off, the wipers do the exact same thing - makes no difference. Thanks for your help!
htt
Old Nov 16, 2018 | 10:36 PM
Alfisti's Avatar
Car: 1986 Contempo Cantara Camaro
Engine: LG4 5.0 V8
Transmission: T5 5 -speed
Re: Bad Wiper Motor?
I am also trying to sort out my wipers.
I think your motor is fine. I think you might have an issue with the gearbox or the black box.
I wonder if your wipers are only using the park circuit?
I connected 12V to the small plug at the end of the motor and can get mine to work off the car. But I plan to open up the electronics and look for any issues.
Old Nov 19, 2018 | 10:36 AM
Car: 1987 Trans Am
Engine: LG4 305
If I was having an issue with the gearbox, wouldn't I still just go ahead and replace the whole unit anyway?
Old Nov 19, 2018 | 11:06 AM
Alfisti's Avatar
Engine: LG4 5.0 V8
Have you found the cover anywhere? If you can find the whole assembly I would definitely replace it all. But I think my problem is in the wiper cover circuit, I am going to see if I can find any bad diodes etc.
Old Nov 19, 2018 | 03:13 PM
Car: 1987 Trans Am
Engine: LG4 305
How can the black cover be tested? With or without the cover on, my wipers operate the same.
Old Nov 21, 2018 | 07:21 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Possibly your all in one wiper switch/turn signal handle could be bad.
Old Nov 21, 2018 | 05:50 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
I like the beat that wiper is playing.Seriously though, id say its the park switch, which is the white piece the harness plugs into.I believe you can buy just the switch.
Old Nov 21, 2018 | 06:49 PM
Car: 1987 Trans Am
Engine: LG4 305
I can't find the park switch anywhere. Can it even be purchased separate from the entire motor assembly?
Old Nov 21, 2018 | 07:11 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
I see them on ebay, some new, some used.They can be pricey depending on the seller.I thought dorman and those type of companies made them.Maybe classic ind, but ive never checked there.
Old Nov 26, 2018 | 12:58 AM
Alfisti's Avatar
Engine: LG4 5.0 V8
I pulled my black wiper cover and there are a bunch of bad components I'm going to try to repair it and see if I can get it running again.
Old Nov 26, 2018 | 10:45 PM
Alfisti's Avatar
Engine: LG4 5.0 V8
Have you checked the small two wire connector down on the bottom of the motor? If that's loose it might only run on the park circuit.
Just to see if mine works at all I plugged it in and ran it without the black cover. I have slow, fast and park just no intermittent.
When mine was on the bench if I applied 12V to the two connectors at the bottom of the motor I got slow, and fast speeds. Try that. If the motor works slow and fast then it's likely a bad switch assembly.
Old Nov 27, 2018 | 02:05 AM
Car: 1987 Trans Am
Engine: LG4 305
For some reason, without touching anything else, I've now got JUST high speed. Didn't touch the thing, just decided to start working. Does this still sound it might be the switch assembly?
Actually, when you say switch assembly, what are you describing? The actual steering column switch assembly? Can these things even be fixed or do they just need replacing?
For example, are you referring to this part: https://www.autozone.com/electrical-...itch/65848_0_0
Or are you referring to the actual "stalk" - or both?
Old Nov 27, 2018 | 11:16 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Its prob. the all in one turn signal stalk.
My 84 Zs wipers only worked on certain speeds and the delay was wonky also you had to fiddle with the cruise
control button to set yer speed. I replaced the stalk and everything works as it should.
The actual headlight "switch" that the stalk fits into is mounted onto the steering column.
https://www.autozone.com/collision-b...lever/112904_0
Old Nov 27, 2018 | 11:19 AM
Car: 1987 Trans Am
Engine: LG4 305
So you reckon this doorman part, and not what I posted a link to earlier, is the culprit?
Old Nov 27, 2018 | 11:28 AM
Alfisti's Avatar
Engine: LG4 5.0 V8
First thing you should check is the ground bolt on the wiper motor. It's the upper bolt on the passenger side. Loosen it then retighten should clean up the connection.
If that doesn't work use a multimeter to check for 12V at the small two wire switch on the bottom of the wiper motor. One wire is slow, one is fast.
If you don't have a multimeter (they are cheap at Harbor Freight, totally worth the investment) use a 12V wire to touch each of the two terminals on the wiper motor. If you have two speeds then it's likely a bad switch.
But do some more troubleshooting before spending any money.
Old Nov 27, 2018 | 10:56 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
The one you posted a link to is the turn signal/flashers switch, no wiper function there.
As for the stalk, there is no wiper function on it.The metal rod fits into a port on the column.When you rotate the stalk for the wipers that rod turns.
Which turns the port it plugs into.That piece is the actual wiper switch.The wire coming out of the stalk is strictly for the cruise control.
Wiper switch.
https://www.autozone.com/electrical-...27933_188578_0
Old Nov 29, 2018 | 04:06 PM
Car: 1987 Trans Am
Engine: LG4 305
Alright, followup!
I just bit the bullet and ordered a whole new motor/cover assembly from hawks. All speeds work great, it's super dope. BUT, new problem:
No washer fluid! I hear the pump TRYING to work and the tank is full, but nothing comes out. I'm not sure what the washer fluid cap SHOULD look like but... surely this is my problem right? If not, what else could it be?
Thanks!
Old Nov 29, 2018 | 07:14 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
There should be a tube on that & it should reach the bottom of the reservoir.That tube would've had a screen on the end as well.
Old Nov 29, 2018 | 08:38 PM
Car: 1987 Trans Am
Engine: LG4 305
In an effort to see what the problem is, i just pulled the hose off the cap and stuck it directly in the tank - tried to run the washer fluid and still the same result: I can hear the pump trying to do its thing, but nothing comes out. Does the cap make all the difference or if the pump is good, should this, in theory, have worked?
Old Nov 29, 2018 | 09:29 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Yes, it shouldve worked.Part of the problem is that crappy pump on motor design.It cavitates too easily, because the pump is higher, the water flows back into the reservoir when not in use.This makes the pump suck air instead when you run it.If you suck on the pump end of the hose & reinstll it to the pump.Then run the system it usually works, but eventually the water draws back out into the reservoir.
Also those pumps burn out frequently or the impeller clogs up and water stops flowing thru, but id at least try drawing water into the hose manually.Then reattach it to the pump & run it to see if the pump is still viable.Another idea, hold a container of water higher than the pump & let gravity flow water down to the pump.This will keep the hose filled & water will be drawn to the pump instantly.
LarryD
Jan 4, 2015 04:52 PM
katrav8
Apr 8, 2013 04:24 PM
