Headlights stuck down
Old May 3, 2019 | 02:30 PM
FreePreview's Avatar
Hi All,
The headlights on my '87 Formula 350 seem to be stuck down.
When I press the headlight button, the headlights come on, the motors spin, but the housings don't go up.
I've tried manually turning the ***** to raise them, no go.
I've tried pulling up on the headlights, but they don't budge.
I've tried pulling up on the headlights when the motors are active, and when I'm just manually turning the *****.
Any suggestions as to why they're not moving?
Old May 3, 2019 | 03:44 PM
Drew's Avatar
Re: Headlights stuck down
Rebuild the headlight motors, the clutch pellets have turned to Parmesan Cheese.
Old May 3, 2019 | 04:20 PM
So even with the gears turned to dust I cant manually lift the headlights? Do you think I just need the replacement gears or will the full rebuild kit be requied?
Old May 3, 2019 | 09:08 PM
Drew's Avatar
Well... The motors turn a worm gear attached to the end of the armature, the worm gear drives a round gear attached with plastic pellet bushings to the arm that lifts the headlight. Turning the manual **** just turns the armature. The worm gear can turn till the cows come home, either by hand or angry pixies, when the pellets are turned into powder, the powder can't bear between the plastic gear and the shaft attached to the arm that lifts the motor.
The pellets are cheap and can be found all over Ebay or any of the restoration/specialty houses that deal with Firebirds, Corvettes, Fieros, etc. You could even get super sneaky and cut chunks off a wooden dowel, or pieces of hot glue stick, but really I think I paid $8 on ebay for a set of Delrin bushings machined to fit exactly. One set of 6 bushings does both motors. Takes longer to get the motor out, then it takes to replace the bushings.
Old May 27, 2019 | 06:37 AM
Wldrushn's Avatar
Car: 1989 Pontiac GTA
Originally Posted by FreePreview
Hi All,
I have the exact same problem. Question: how to replace motor or bushings when headlights stuck in down position? Everywhere I look the assumption is you are starting work with headlight up!
Old May 27, 2019 | 08:32 AM
So I've now fixed mine, I used TDS's rebuild kit for gaskets/bushings, and that fixed them right up. Best thing I can advise is to take the whole assembly out first (2 bolts up top, 2 underneath). You'll have to jack the front end up to get to the ones on the bottom, unless you can squeeze your arm and a 10mm socket wrench underneath, which I was able to do. But for first time taking them off, you'll want the car jacked up.
With the assembly out, try to get the 10mm nut off the actuator arm. If that's off the lights can rotate freely. That's the best option from what I can tell.
Old May 27, 2019 | 09:01 PM
Hawkeye1980's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7
Axle/Gears: Stock
there is a manual dial that you can turn to get them up. It takes a bit but works every time. I had to do that so I could rebuild the motors.
Old May 27, 2019 | 09:59 PM
Drew's Avatar
If the pellets are completely shot, you can sit there turning the **** until the Yellowstone caldera erupts and the headlights won't come up.
Old Jun 18, 2019 | 06:28 PM
RandyNJ's Avatar
If the gear is stripped would turning the **** manually lift them or does that 100% mean it's the pellets? I'm having the same issue. Also, are the brass gears made for 91's? I only saw them online for 93+.
Old Jun 18, 2019 | 07:44 PM
Nope. Just go ahead and remove the 4 bolts (2 top and 2 underneath) holding the whole headlight/motor assembly in place to take the whole thing out. You can then unbolt the motor, take it apart, and replace the bushings. Don't try to force the headlights up. They won't go up until you fix the bushings.
Old Jun 18, 2019 | 10:18 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Ask Lon at topdown solutions! Hes got the parts and repair tips to fix your lights.
http://www.top-downsolutions.com/
Old Jun 30, 2019 | 09:50 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
You can get it to come up, but you've waited so long to do the repair that you've turned a 1-man job into a 2-man job. Have someone get in the car and press on and off the headlight switch. You will grab hold of the headlightdoir lid. Your job is to bang, shake and curse the headlight while you continue to hit it and curse. Eventually it will suddenly rise ( if you don't run out of curse words). Once you have it up you can proceed with the repair following the instructions.
Good luck.
Lon
Schwinny
Aug 18, 2012 11:52 AM
anesthes
Mar 23, 2004 06:01 AM
dimented24x7
Jun 27, 2002 06:10 PM
TomP
Mar 19, 2002 03:39 PM
Josh91Bird
Oct 16, 2001 06:56 AM
