Metal dragging sound
Old Jun 19, 2019 | 10:27 AM
RandyNJ's Avatar
Car is making a loud sound as if metal is dragging the road only when accelerating up to about 20mph. It's so loud that driving behind the car the sound can be heard. I've looked up videos of people having similar issues and none sound similar. There doesn't seem to be any driving complications, so I'm hoping it's not something major?
Old Jun 19, 2019 | 11:10 AM
Billgluckman's Avatar
Re: Metal dragging sound
Have you got under the car and looked?
No one is going to be able to tell you what’s wrong with that info
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Have you inspected the underside of the vehicle?
Old Jun 19, 2019 | 11:24 AM
RandyNJ's Avatar
I wouldn't be posting if I hadn't. There's nothing visibly loose.
Old Jun 19, 2019 | 11:36 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
I'd suspect a broken engine and/or transmission mount as a first guess.
Old Jun 19, 2019 | 11:41 AM
Put the rear of the car on jackstands and accelerate. See if the noise occurs and try to pinpoint it.
Old Jun 19, 2019 | 02:26 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Check the parking brake adjuster to make sure it is not hanging and rubbing on the driveshaft or maybe the parking brake cables on the driveshaft
Old Jun 19, 2019 | 04:04 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
buy a cheap bluetooth mic and zip tie it to parts of the car recording with your cell phone until you find where its loudest. Our buy a mechanics ear that comes with several mics.
Things to look at:
Wheel bearings on the front.
brake pads (especially the squeal tabs)
transmission mount (tail housing)
U joints play/bent tourq arm rubbing drive shaft.
rear diff/axle
what year car, if mechanical speedo check that cable
Old Jun 19, 2019 | 04:07 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Also depending on your wheels make sure no one stuck rocks in your hub cap, center cap, etc
Old Jun 19, 2019 | 04:59 PM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
brake disc dust shield bent?
Old Jun 20, 2019 | 09:06 AM
RJ IROC's Avatar
Car: 1985 Camaro IROC-Z
Engine: 383 HSR Comp XFI280HR Profiler 195s
Axle/Gears: 3.73 Posi
^^^^^^THIS^^^^^ I had a sound like this for the longest time, and it was the parking brake adjuster rubbing on the driveshaft. The cables came out of the groove they were supposed to ride in. I'd bet money that's where your problem is. Try yanking the ebrake a few times and see if the sound changes or gets worse/better while you're driving.
Old Jun 24, 2023 | 12:10 AM
Toqwik's Avatar
I would jack it up and have someone heavy sit in the hatch area to simulate the car squatting during acceleration. Next thought would be has your muffler came apart internally. Spin the tires on some grass and see if it happens.
Old Jun 24, 2023 | 08:45 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Could be the inside piece of the muffler moving around.
Old Jun 24, 2023 | 11:49 AM
Edwardgp's Avatar
Engine: 454-350
Toqwik this one is your fault, digging up bones jeez I need new glasses.
nashoba01
Brakes
Nov 23, 2013 06:29 AM
FYRCHKN
May 31, 2008 08:01 AM
HamsterOnaMission
Jun 9, 2005 01:43 PM
Dingley
Oct 14, 2003 11:21 AM
yellowZ28ragtop
Nov 16, 2001 07:17 PM
