Rear hatch strut bolt
Old May 16, 2020 | 08:27 AM
NotoriousREV's Avatar
Because I’m a ham-fisted idiot, I cross threaded the torx head shoulder bolt at the bottom of the strut where it bolts to the body and snapped it. I’ve tried using easy-outs but it won’t shift so I’m going to have to drill it and helicoil it but I’ve no idea what thread the bolt is. Anybody know?
Old May 16, 2020 | 01:45 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Rear hatch strut bolt
Take out the bolt from the other side and measure it?
I doubt the hardware store will have shoulder bolts but you can use their thread gauge.
Old May 16, 2020 | 04:49 PM
Drew's Avatar
It'll be a metric thread. Probably an M8 or M10.
Old May 16, 2020 | 10:22 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
How did you snap the thick mother?
Old May 17, 2020 | 10:23 AM
Thanks, I think it's an M8. I'm based in the UK and wasn't sure whether it would be metric or imperial. I thought you guys hated metric
Old May 17, 2020 | 10:24 AM
I snapped the thin bit. Just kept swinging on it even though it was getting hard to turn (because it had jammed up due to crossthreading it). As I said, I'm an idiot.
Old May 17, 2020 | 10:25 AM
I've managed to find someone selling shoulder bolts on eBay that are the right dimensions, but with an M10 thread instead of M8, so I'll drill it out and fit an M10 helicoil and pretend it never happened.
Old May 17, 2020 | 10:35 AM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
Check a good hardware store for metal "Bushings". ("Bushes" in your part of the world) You may be able to use one to shoulder a regular bolt. Helicoil to OE size.
Old May 17, 2020 | 11:06 AM
The only "off the shelf" bushings I can find that are 25mm diameter are drilled for M10 bolts. I don't think drilling out to an M10 will be a problem, there's plenty of metal there to go at.
91R5
Jan 8, 2016 05:50 PM
mav75
Oct 19, 2013 02:49 PM
3-Ball
Mar 5, 2010 01:18 PM
racing geek
Sep 5, 2008 03:19 PM
johndinu
Aug 25, 2005 12:14 AM
