Hatch alignment and paint + aero wing
Old May 9, 2021 | 10:36 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Started the process of stripping the hatch down to realign the overhang and paint the deck lid and spoiler (the fiberglass spoiler has been in primer since 2001). Unfortunately the spoiler has some damage from a tree branch several years ago, but there will be no waves when finished.
Hatch removed
The glass mount holes and play you have to work with
Old overhang
Paint prep for the spoiler
Test fit to make sure I could get it even
PVC pipe paint booth
Old May 10, 2021 | 12:15 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Re: Hatch alignment and paint + aero wing
what torque did you tighten the decklid nuts to?
Im so scared to break the glass!!!
Old May 10, 2021 | 12:38 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
https://www.thirdgen.org/hatchalign/
https://www.thirdgen.org/forums/body...ear-glass.html
https://www.thirdgen.org/forums/body...ear-hatch.html
Old May 10, 2021 | 12:59 PM
1989karr's Avatar
Engine: 3.4 / 5.0
ahh thank you!!!
Old May 10, 2021 | 07:43 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Painted the underside of the deck lid and the new tail light housing. Also ordered the aluminum hinges from Hawks. This almost done re adjusting the gaps after having it apart for the LS swap and paint touch ups.
Old May 12, 2021 | 03:06 PM
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 355/AFR 210
Transmission: POWERGLIDE
Axle/Gears: MOSER 12 BOLT 5.36 1/8 MILE ONLY
So it look like 8 bolts that hold painted hatch part to glass? Is that all? Mine needs alignment as well. Thanks, Frank
Old May 12, 2021 | 03:15 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Its actually only the 4 leading bolts that go through the glass, the other bolts only goes through the metal frame that is on the bottom of the glass and what the struts mount to. There are also so me self tappers that hold the glass surround to that same metal piece.
It all makes sense when you get into it. I'm going to take the glass fully off the car so I can better paint the glass surround. The 20 year old rattle can trim paint needs replaced this time I'm using proper automotive 2k paint.
Old May 12, 2021 | 03:27 PM
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 355/AFR 210
Is it dificult to loosen up and adjust into place? I was told there is sealer that holds that in place.
Old May 12, 2021 | 03:35 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
You might be able to push it forward didn't try. To do it correctly you really should take it off, remove the old sealer and put new sealer tape and re mount it. You can adjust it some at the hinge bolts (glass side not car side) if you didn't want to go all in.
Old May 12, 2021 | 03:38 PM
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 355/AFR 210
Already tried at hinges, What type of sealer is used?
Old May 12, 2021 | 05:28 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
This is what I bought I also have a tube of windshield adhesive. I am thinking I may put a spot of it to help keep it from being pushed back.
https://smile.amazon.com/dp/B000CQ4A...ing=UTF8&psc=1
At the hinges on the hinge to body mount there is no forward aft. But on the hinge to glass it has about 1/4 inch play. If it's all the way forward their then either hinges are bent or deck lid has slid.
Old May 13, 2021 | 07:57 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Not bad considering how little I paint.
Old May 15, 2021 | 02:09 PM
Hawkeye1980's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7
Axle/Gears: Stock
I did this and have to do it all over. I used the heavy duty support shocks for the heavy factory aero wing spoiler. I since replaced it with a lighter fiberglass one from Hawks. Was told I need to use the shocks from a firebird that dont have a spoiler or has the straight wing one. ASM 4967.
I hate having to have to pull off the deck and re tighten it to the glass very nervous doing so again.
Old May 18, 2021 | 08:35 AM
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 355/AFR 210
Do you have any pictures of you applying adhessive before assembly? Thanks, Frank
Old May 18, 2021 | 06:23 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
painting is taking longer than expected. I will take pictures when I assemble it... Still debating the adhesive as it needs to be where I can cut it off if needed in the future.
Old May 19, 2021 | 09:28 AM
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 355/AFR 210
Got it, Thank you.
Old May 24, 2021 | 10:51 AM
Engine: 5.7
Axle/Gears: Stock
Good video for this
Its a bit long but very detailed. I used it to do mine last year. Unfortunately I have to do it again. I used the stock shock supports and it pushed out the deck again. Being I replace my cracked heavy rubber aerowing spoiler with a fiberglass one from Hawks, the shocks i used were for the heavy rubber one. I was informed on this site to use one from a bird that has the single wing spoiler, not as strong. Got them from Rock Auto, AMS Automotive part number 4967.
Now i have to pull it all apart and do over, BLAH!
Old May 24, 2021 | 12:09 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Originally Posted by Hawkeye1980
Good video for this
https://www.youtube.com/watch?v=UPPU8AZAQps
this is how detailed every vid should be!
Old May 24, 2021 | 08:06 PM
Engine: 5.7
Axle/Gears: Stock
I agree. It is very well documented.
Old May 29, 2021 | 06:06 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Figured out a easier and safer way to lift the glass. Everything is now painted and cleaned. Assembly starts tomorrow. I'll take more detailed pictures of the assembly than the cleaning/paint. Yes I took the metal frame off the glass to paint.
Old Jul 14, 2021 | 12:20 PM
1989karr's Avatar
Engine: 3.4 / 5.0
How is the assembly going?
Old Jul 14, 2021 | 01:09 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
I got busy and forgot to post the final.
butyl rope location
decided to put some butyl at each bolt
the final butyl layout
tape it up to protect the paint
old hinge
New Hinge install, painted metal surround re installed
tapped up for install
Butyl tape under hinge
sitting in place
use tie down strips (and tape to protect the paint on the metal surround, a line and tape markers so you can lift and bolt.
Alignment tape
Single person operation, I had an engine hoist hooked to it to open and close it
Old Jul 14, 2021 | 01:12 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
The shape of the spoiler is hard to paint right, I may re spray it again later
Final product, the spoiler is just sitting there in the picture, I need to grab a picture of the final final with the new center tail light housing and NOS center tail light and after buffing the entire car
Old Jul 14, 2021 | 02:03 PM
1989karr's Avatar
Engine: 3.4 / 5.0
thats nice! did you use the original hinge / bolts at the glass?
Theres some discussion about if the HAWKS hinges are giving issues
Old Jul 14, 2021 | 02:45 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
I used the HAWKS hinges but I kept my original tucked away just in case. I truly don't think there is any flex in my original ones one was somewhat stiff. I just repainted the bolts through the glass.
One thing to note one of the studs free spun when I tried to take it off so had to slot it and then one turned loose when I was putting it together so I tacked it in place. Moral of the story is clean the threads after painting it and use some pb or something before removing the bolts.
Otherwise painless just time consuming-- especially when you realize you were not quite in the mood for a project--
Old Jul 14, 2021 | 07:06 PM
1989karr's Avatar
Engine: 3.4 / 5.0
im just super scared of breaking the glass lol
Old Jul 14, 2021 | 07:51 PM
Mikos_89's Avatar
Car: '89 GTA, '15 Camaro LS 6sp.
Engine: L98, LFX.
Transmission: 4L60, AY6.
Axle/Gears: 3.27's.
The paint came out looking great! How did you prep the fiberglass spoiler for paint? When you resprayed the decklid, did you use a 2K primer as a sealer and then the basecoat/clearcoat over that? Thanks.
Old Jul 14, 2021 | 08:00 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
PPG shopline (rest of the car is 20 year old macco so have to balance it)
I sanded and blocked the spoiler 5-6 times before paint mainly because I kept getting runs in the primer/sealer also PPG.
Old Jul 14, 2021 | 08:02 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Only way you will break the glass is dropping it or having something between the glass when you torque it down. I'm pretty sure you will snap the stud off before braking it. I used the specs I linked to earlier.
Old Jul 15, 2021 | 12:26 PM
1989karr's Avatar
Engine: 3.4 / 5.0
that's good to know!
Please post your finished pics when you can!!
Rellim88
Exterior Parts for Sale
Mar 7, 2021 06:30 PM
dwint
Jul 17, 2008 08:41 AM
SKYROC
Jan 19, 2008 12:31 PM
davecamaro
19
May 22, 2005 05:18 PM
