Window Travel Downwards
Old May 26, 2022 | 12:18 PM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
1984 T/A - Is there an adjustment to reduce the downward travel of the glass in the door? When I had the door trim off, I could find no method of adjustment. I want to reduce the travel in the driver's door.
Old May 26, 2022 | 03:56 PM
KEVIN G.'s Avatar
Car: 1984 TRANS AM AERO (PAINT SO DEEP
Engine: 305 CARBED
Transmission: 700 R-4/Vette Servo mod
Re: Window Travel Downwards
One question, why? You can move the stops, but not much.(And it may only be for the "up" position...for water leaks and adjustment to the roof, you might not be able to adjust for the down position at all)
If memory serves, they're an "L" shaped bracket on face of the inner shell, you will only be able to see a bolt with a 10mm head, and a groove with a tab. The actual bracket is inside with the window track. The tab grabs a corresponding tab mounted to the track or glass itself.
Old May 26, 2022 | 06:10 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
The window should stop right after it reaches the top of the belt mouldin. If not, the rubber bump stop wchihch goes bad probably went bad and crumbled.
Old May 26, 2022 | 10:12 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
#6 is the up stop for the rear part of the glass. Its just a small block that fits in that vertical guide and the roller in that guide slams into it once at full up. You could probably rig up something like that on the lower part of the guide to stop the window from going all the way down. This is from my 84 camaro FSM, so should be the same for your 84 bird.
Old May 27, 2022 | 10:20 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
There are rubber tipped bumpers at the bottom of the window that rest on the inner door shell when down. Those are about always shot and let the window go down too far and really make noise when you shut the door with the window down. Couple posts on here on replacing those.
Old Jun 4, 2022 | 01:39 PM
tajoe's Avatar
Car: 84 Trans Am
Engine: Turbo 301
Nice breakdown of the guts. Is there a way to turn the pic 90°?
Old Jun 4, 2022 | 02:12 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Old Jun 4, 2022 | 06:10 PM
tajoe's Avatar
Car: 84 Trans Am
Engine: Turbo 301
Much better. My neck thanks you.
P.S. I wish I had this picture last week, when I swapped out my window regulators. Would've been a big help.
Old Jun 4, 2022 | 06:50 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Old Jun 4, 2022 | 07:08 PM
tajoe's Avatar
Car: 84 Trans Am
Engine: Turbo 301
LOL. That must be the "Chinese" version.
Old Jun 4, 2022 | 07:15 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
In case someone who likes to hang from the ceiling while reading this.
Old Jun 4, 2022 | 07:19 PM
tajoe's Avatar
Car: 84 Trans Am
Engine: Turbo 301
You mean like in one of those "Gravity Guiding Tables?"
(Nice looking RS) Drop top, and all.
Old Jun 4, 2022 | 07:38 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Yeah, or maybe one of us is a vampire.
Old Jun 4, 2022 | 09:54 PM
tajoe's Avatar
Car: 84 Trans Am
Engine: Turbo 301
"And now back to our regularly scheduled program"
Old Jun 4, 2022 | 10:53 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Old Jun 5, 2022 | 12:54 AM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Thanks, this is useful. I have to take my passenger door apart tomorrow to put my window back on the track.
Old Jun 7, 2022 | 10:40 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Also instead of buying the OE lower bump stops use a brake shoe off a bike!
Old Jun 7, 2022 | 10:49 AM
350Iroc89's Avatar
Car: 1989 Camaro IROC Z
Transmission: 4L60
Axle/Gears: 2.77 G80 9 bolt
There's a member that sells the rubber bump stops in the classified section. They always rot and crumble which lets the window drop too low. You will want to fix it before it chips the edge of the glass from the belt molding bolts hitting it. It's a simple install with a rivet once you get the old junk out.
Old Jun 7, 2022 | 03:08 PM
1989karr's Avatar
Engine: 3.4 / 5.0
I bought his stuff... really good!
Old Jun 7, 2022 | 03:22 PM
tajoe's Avatar
Car: 84 Trans Am
Engine: Turbo 301
Good to know. I'll need to check mine out, while the door panels are off. Wonder if he sells the feather seals on the window sills.
Gladstoneiroc
Nov 12, 2016 08:18 PM
gholian
European Region
Oct 14, 2013 02:49 PM
N_da_Mood
May 28, 2012 10:29 PM
macmatt
May 23, 2011 11:13 PM
ken3983
Jun 28, 2006 04:50 PM
