What is this sticky pad
Old Apr 4, 2023 | 02:59 PM
wildjeff's Avatar
Car: 1983 Trans Am
Engine: L69 5.0L HO
Transmission: Manual
What is this sticky pad called? its under the carpet. stick on both sides. it covers holes in the body. I need to replace a few of them.
What is its name and where can i buy some?
I'll also need to clean off the old one. its been may years since the carpet was removed. Is there any tips on removing the old one?
Old Apr 5, 2023 | 12:41 AM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
Re: What is this sticky pad
I call it a sticky pad. There is no official GM name for it.
Dont worry about it. Or if you are just that picky that the thought of a worn out sticky pad out of sight UNDER the carpet keeps you from sleeping at night just grab a tube of seam sealer and smooth it over.
And if you insist on cleaning off the old gooey substance use lacquer thinner or standard paint thinner.
If you spend a lot of time worrying about this petty crap you will probably never drive and enjoy that car like it was made to be. Dont overthink it.
Old Apr 5, 2023 | 05:08 PM
altiller's Avatar
Car: 92 Convertible Z28
Engine: 5.7
Have removed this from other vehicles.....grab some dry ice and a hammer. Once its really cold you can just whack it a bit and it will shatter.
Old Apr 5, 2023 | 05:49 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
There should aslo be a metal plug or something that coves that hole
Old Apr 5, 2023 | 07:43 PM
wildjeff's Avatar
Car: 1983 Trans Am
Engine: L69 5.0L HO
I have the metal plugs. I dismantled the car in 2007 and moved twice since then but i did take many pictures and have the parts packed and labeled. its been a long time but I'm ready to start putting it back together.
88 350 tpi formula
Convertibles
Jun 25, 2022 01:01 PM
jchaussee
Jan 16, 2011 12:10 PM
*84TA
Jul 14, 2010 02:03 PM
florida_gators
Aug 13, 2009 12:25 PM
t/adreams
May 19, 2007 10:39 PM
