Hatch locking cylinder
Old Mar 15, 2026 | 09:49 PM
Thirdgenstudent's Avatar
Ever since I’ve owned my car the black cover on the lock cylinder for the hatch has been missing. The key works fine though and it turns freely to open the hatch. Recently I purchased a black pair of cylinders from a local parts store and was wondering if I could remove just the black part and install it onto my cylinder. Sure I could replace the whole cylinder but would hate to have one key for the hatch that’s different from the doors. I briefly tried to pry off the black cover from the new cylinder bout it seems like it’s on there pretty good! Plus if I do get it off how would I affix it to the existing cylinder. Anyone have any experience with this? Thanks in advance.
Old Mar 16, 2026 | 11:02 AM
Beeman's Avatar
Re: Hatch locking cylinder
A good locksmith shop should be able to help you. Replacement covers have 4 tabs that you peen over when you install them. Trying to pry off a cover from a new cylinder will just make junk. There are 2 little springs that go in the 2 holes in the face of your cylinder and they keep the shutter in place before installing the cap. Look for a non keyed cylinder and it will come with all of the parts loose.
Old Mar 16, 2026 | 11:28 AM
Thank u so much for the information. I figured I would damage it trying to get it off. Maybe I’ll look for a good locksmith
Old Mar 17, 2026 | 06:36 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
The pontiac hatch has a differetn setup. the ones in the pic look like the camaro hatch / camaro / firebird door locks.
Honeslty though im not sure where you would find a repalcement?
Old Mar 17, 2026 | 06:38 PM
You are right the pics are of door locks. I figured if I only needed the black cover part it didn’t matter. But unfortunately after reading a previous reply to my post it looks as if it’s impossible to remove just the black part??? Might just have to live with it???
Old Mar 19, 2026 | 03:07 PM
1989karr's Avatar
Engine: 3.4 / 5.0
foun!! hawks make a replacement unit
1986-1992 Firebird Electric Rear Hatch Pull Down Lock Cylinder Set w/ Keys PY464 | eBay
Old Mar 19, 2026 | 03:09 PM
Awesome thank you so much
Old Mar 19, 2026 | 03:11 PM
1989karr's Avatar
Engine: 3.4 / 5.0
no prob! If I recall though... the original is riveted in unfortunately, so it is not a simple unbolt / swap
Old Mar 19, 2026 | 03:12 PM
As long as there’s a replacement I’ll figure it out
Giertick
Exterior Parts Wanted
Jan 16, 2014 05:38 PM
paw_01
Interior Parts Wanted
Oct 13, 2008 08:02 PM
JohnC
Apr 5, 2008 04:54 PM
KrazyKaycee
Jan 13, 2008 06:18 PM
transam84
Mar 23, 2002 02:30 PM
