help with grant steering wheel
Old Feb 11, 2002 | 09:35 AM
brihoop's Avatar
i just bought a new grant steering wheel and i am having some trouble with it... i got it on, but the steerin wheel isnt straight, its sideways and i couldnt figure out how to get it to be straight, and also i can not figure out how to get the horn to work right, if anyone knows anything please let me know....
Old Feb 11, 2002 | 09:53 AM
Camrs89's Avatar
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
my horn doesnt work also...i have the black spoke wheel from grant
Old Feb 11, 2002 | 10:10 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The horn on my Grant wouldn't work until I grounded the horn cap to one of the mounting bolts. I'm not sure what you mean by straight. If the wheel has just been mounted incorrectly, you'll have to remove it and reposition.
JamesC
Old Feb 11, 2002 | 11:47 AM
Black85TransAm's Avatar
Well it ha been my experience that 90% of people with Grant GT's , their horns end up not working....mines the same way...as far as positionsing goes ....all your have to do is hold the steering wheel straight while u tighten the bolt that holds it on ..or thats how it worked out for me...hope this helps....
Old Feb 11, 2002 | 11:51 AM
mtccl's Avatar
Make sure your wheels are straight when you roll to a stop on a level surface. Remove the wheel. Remove the adapter and reposition on the steering column teeth until the wheel is straight. As for the horn, you have a ground wire coming from the horn that goes to the horn button. Run the other to the adapter kit mounting bolt. You may have to drill a small hole and insert a screw in the adapter to have a place to run the wire to. It will ground thru the steering column and the horn will work. Good Luck!!
Old Feb 11, 2002 | 12:04 PM
Bluerocket's Avatar
When I installed my grant wheel I followed the directions whith the wheel. I got every thing perfect. on the painted wheels you need to use the sliver sicker to properly ground the horn. you must also remove the horn botton from the column and use the wire provided with the install kit
As for the wheel being crooked make sure the wheels are pointing forward and then remove the wheel and the adapter and place back on in the proper way.
Old Feb 11, 2002 | 12:24 PM
imokureok4's Avatar
Where does that silver sticker go???
Old Feb 11, 2002 | 01:02 PM
Bluerocket's Avatar
what series wheel do you have mine is classic series and the sticker went under the horn button. Do you have a challenger? If you do the install will be different.
Old Feb 11, 2002 | 01:04 PM
brihoop's Avatar
i have a challenger
Old Feb 11, 2002 | 04:13 PM
Bluerocket's Avatar
Than the sticker wont work on it. It is different from mine.
Hotrodboba400
Dec 10, 2019 07:07 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
SG91camaro
Sep 5, 2015 10:27 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
