ceiling dome lamp console Q's
Old Mar 20, 2002 | 01:01 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
ok in 84 on the ceiling console thing, theres a about a 2x6" rectangle plug or cover or something with thread stitches around the border of it, is it supposed to be able to be removed ? it look slike it can but maybe its not ? also just behind it towards rear of car on face of the console thing there small rectangle opening and some metal springy contact tang back inside there, what was in this originall ? i finall yfound out what those two small button switches up there were for once I got the fuse replaced, ones for the dome and other is for map, heh
then theres a trip odometer thing and a date thing up there too
what else is up there i dotn know about, i think something is missing regarding that open rectangle deal, anyone know ?
thanks
Old Mar 20, 2002 | 01:19 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I believe you're describing the sunglass pouch, a leatherette affair that could be removed (though you'd need to pull the console to do it). I assume it's missing. Directly behind it toward the dome light was a slot for the flashlight, which was a rectangular piece that simply pushed in. It was held in place by a small clip on the flashlight body itself.
JamesC
Old Mar 20, 2002 | 03:58 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
so is that sunglass pouch cover a delete plate then ? flashlight thing from factory ? hmm interesting.. i rmeoved the console assembly today to remove the headliner earlier to clean it and get it ready to repair and recover, i oculdnt learn much new about the console by looking at it from the backside, heh
thanks!
Old Mar 20, 2002 | 05:36 PM
JamesC's Avatar
Perhaps a pic will help. Seeing the front of the flashing, since it sits flush, is difficult, but it is there. Note the sunglass pouch.
JamesC
Old Mar 20, 2002 | 08:54 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
interesting, mine doesnt have pouch, but instead it has a block off or delete plate, heh, made of same material as the rest of the console, flashlight stuff is missing too,
hmm
thanks !
Old Mar 21, 2002 | 06:27 AM
JamesC's Avatar
If I call correctly, the edges of the pouch are tucked around this 'plate' as you call it. I've seen many of these consoles and sold quite a few, but I've never seen one without the pouch. My "guess" is that someone's removed it.
JamesC
Old Mar 9, 2003 | 10:50 PM
xChRiSx's Avatar
I cant get that dome light console off of my roof, i only found 2 screws, around the dome light, and there is still somehting holding the console on. my guess is that the other screws are behind the pouch, but i didnt want to break it.
Old Mar 10, 2003 | 06:00 AM
JamesC's Avatar
Do a search on my name and you'll find a thread having to do with the differences in the t-top and coupe versions of the overhead. There you'll see that both have four mounting slots forward. You either push the console toward the windshield or pull it toward the hatch, after removing the two screws you mention, for removal. Depends on the overhead you have.
JamesC
Old Mar 10, 2003 | 08:15 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
I've seen a couple that didn't have the sunglasses pouch.
I use mine for holding my cellphone, I have it in the pouch, and the intenna goes into the flashlight hole since I dont have a camaro flash light. I like it and its not noticeable and easy to get to when it rings.
Old Mar 11, 2003 | 10:52 PM
xChRiSx's Avatar
I figured it out on my own yestersday, but thanks for the help. I thought nobody was responding to my threads but i forgot i used a diff. email address when i registered here
Old Mar 16, 2003 | 02:50 AM
WalkerZ28's Avatar
Hey JamesC, would it be hard for me to install a overhead console in my car if it did not originally have one?
Old Mar 16, 2003 | 07:16 AM
JamesC's Avatar
WalkerZ,
Here's a thread I posted some time ago that will answer your questions. Also, IROCdave, has a tech article that should shed more light, should you need it. By the way, the Camaro White Book doesn't list the Overhead (DK6) for 1988.
If you have other questions, let me know.
JamesC
https://www.thirdgen.org/techbb2/sho...threadid=99782
Old Mar 16, 2003 | 12:02 PM
89cmrodriver's Avatar
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
the console is very east to install, its harder to wire it correctly than it is to install. the holes are already on the center support br for hte roof all u have to do is put 4 1/2" screws in the front slide it on and put 2 3/4" screws int eh holes in the dome light part, estiamted time: under 15 minutes
Veaceonee
Sep 29, 2016 08:15 PM
Lbibb
May 5, 2016 12:00 AM
1992Z28!
Nov 19, 2015 07:33 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
ndndndnd
Sep 28, 2015 08:00 AM
