SSBC Force 10 Dual piston calipers...1LE alternative???
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I just got this month's issue of Car Craft and there's an article on SSBC's new Force 10 (FX2) series brakes for GM cars, including Camaros/Firebirds. They go as far as to say you can get them with slotted 12" rotors and the calipers bolt up to standard front spindles. They look sweet, come with EBC pads, and the package goes for about $350. I'm curious as to how they'd compare to the 1LEs performance wise. With no modifications necessary, it sound real sweet.
Along the same lines, maybe these calipers can bolt onto '88 and earlier rear disc systems...Hmmm. Aren't the calipers on these rears VERY close to the front iron calipers? I got rid of my '88 rear so I can't compare them.
Here's the link to the site and the info on them:
http://www.ssbrakes.com/products/#FX...20Brake%20Kits
I'll give them a call next week and post what I hear back from them.
Ed
Ed
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I read the same article with great interest. I'll be interested in what the company's response is. Please post.
JamesC
By the way, many thanks for the pics of your 1LE upgrade.
JamesC
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
I think your price of $350 is a little off..........all their kits approach $850-1250.
According to the article, the "Super Twin calipers retail for $395 with pads and hardward, or for a total of $550 you can add a set of plated and slotted 11-inch rotors. Powdercoating is also available for an additional charge."
JamesC
JamesC
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
$350 is a damn good price but hard to believe. if they're that cheap i'd go otu and but them quick
But if they can put 11" rotors in there, that's ALMOST an instant 1LE setup without the need to convert with all those brackets and such.
Again, my big question for them is the possibility of putting the calipers on the '88 and older disc rears that have the screw in style piston iron calipers. This would be a sweet setup to have on all 4 corners, IMO.
JamesC, thank you
Ed
Check this thread for more info about the kit. http://www.stainlesssteelbrakes.com/products/
Go to Quick Change Caliper Upgrade Kits.
JamesC
JamesC
Engine: 4.0L
JamesC
JamesC
Yeah, they don't list any pricing (which sucks). They also offer an emergency brake kit so I still think these should fit on the rear. It is described in the Force 10 FX4 kits.
Ed
BTW: The kits we should be interested in are the Quick Change Caliper Upgrade Kits.
Ed
There is no mention of a spindle mod either in the Car Craft article or on the web site, but who knows. Any info is appreciated.
JamesC
JamesC
doesnt that use the stock 10in rotor
BUT...maybe the 1LE rotor would be too thick.
Guess we'll be asking a lot of questions for the tech guy, huh??
Ed
I Just spoke with them, it fits the stock rotor ONLY! he said its improves the braking by 10%. Their rotor upgrade is for the stock size, and if you want the cailper powder coated its additional 100.00 plus and it doesnt come with new brake hoses, so you have to use your old one, which defeats the purpose, IMO.
Its a nice option to have but I would upgrade to 1LE
Do our cars really use the same setup as 1st gens?!
Zerstörer, that $1000 1LE kit comes with a lot of other stuff, including spindles, brackets, rotors, and other stuff. This kit (Quick Change Caliper Upgrade Kits) is just calipers and maybe pads.
Ed
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
You will never be able to go to 12" rotors (or likely 11 ones either) on the stock brake system spindles without having to at least cut the caliper mounting ears off...... Not that cutting them off is all that difficult, but just thought I would point that out. Those caliper only upgrades are nice and all, but I am interested in a seperate hub setup so rotor replacement becomes much easier (and cheaper). I had looked at the C5 option but am now talking with a friend of mine that does Wilwood kits for 4th gens about making a setup for 3rd gens......
I might but not for a while, I just replaced all hoses and front calipers on my RS a month ago. I didn't know about these or I probably would have.
Ed
Ed
Has this company been around for a while? Or are they pretty new? Do you guys think their brakes are comparable to Baer or other high performance kits (1LE, etc). I might be upgrading my brakes pretty soon and since I'm gonna be running 18" wheels I'm thinking about huge rotors front and back with dual piston calipers. Just wondering what you guys think about the quality of these kits. Thanks!!
Has this company been around for a while? Do you guys think their brakes are comparable to Baer or other high performance kits (1LE, etc).
Ed
I just got off the phone with them and got the same info as SLP_GTA did, so that's all I know. Looks like a great caliper upgrade but that's it. If you want/need bigger rotors and better braking power, looks like you're still looking at 1LE, Baer, or a complete SSBC upgrade.
Also, these won't replace the iron rear calipers which is what I was looking for. I think there would be HUGE market for good quality bolt-on replacement calipers for the pre-PBR calipers. If that could be done, a lot of disc rears could come up to par with the PBR disc rears.
Ed
Ed
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Ed
Ed
As far as the front goes, for that price you could just about buy the aerospace components front kit, 10.25" rotors drilled, 4 piston calipers, etc, its like $5xx from jegs.
But the Iron disc ones used smaller rotors, so you'd again just get a better caliper on the small 10.xx rotors, and need a new backing plate for it
Ed
Car: 2004 GTO
Ed
Ed
Hotrodboba400
Dec 10, 2019 07:07 PM
codeysabatini
Nov 10, 2015 04:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
